The following information is to assist you in performing the right connections. You should take precautionary measures such as grounding yourself and completely disconnecting the PC form any source of power.
This picture shows the connector for the front panel power
button, reset button, and power and hard disk lights: an 8x2 pin
connector with
1 pin missing:
The table below lists the pinouts for the connector. The orientation of
this
table is the same as the picture above, this shows the top part of the
connector. All the pins below pin 8 appear to be non-connected.
Each pair of pins labeled Power and Reset goes to the 2 wires for the
corresponding button. The hard disk and power LED wires connect to the
corresponding LEDs, you need to ensure the proper polarity of the + and -
wires
for each LED or it will not illuminate.
The above information is for your information only.
