Orion STV2763 27" TV Logo
Posted on Apr 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Orion TVD2710. Lost remote, can't change signal input
Orion Model TVD2710 (not STV2763). Lost remote control and need to changes input settings so kids can play XBox. Defaults to 'Ant' and no obvious way to change. No front of right side panel manual controls that I could find. Only Channel/Volume/Power manual controls on Front. I found that if I hit Volume up/down simultaneously, a setup menu would come on screen but nothing to change TV inputs away from 'Ant'. I was able to program an 'All-for-One' remote to controls TV Channel/Volume/Power but nothing to adjust signal input setting.
Anonymous
Level 2:
Scholar:
  • Expert 103 Answers
  • Posted on Apr 06, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
103
Questions
0
Helped
42776
Points
335
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
  • jenjensen73 Feb 28, 2011
    on most tv's hooked up to cable or statelite, all you have to do is push the TV channel button down and it will change the input
I have a orion tv with a universal remote, how do i change the imput
It depends on the set on which is is used and if all the functions match on the remote for the model of the TV chosen.
You have not specified the make/model of the universal remote as a referance to the make will confirm the case.
We lost remote control for our Orion 27" Television. Trying to switch input from Antenna 1 so kids can use XBox
Tries use the front or right side panel manual controls panel.Use the Channels buttons UP/DOWN push the channels UP button couple time.U should get in Video 1 or 2 which ever ur video game console hook in.Or your tv might just have a manual video button,put that u in video 1 or 2.Try website 1-800-remotes Factory original to buy an exact remote ur problem solved.None the solutions,help.
I cant change input without a remote how do i do this?
Unfortunately Orion has no other way to switch the inputs but with the remote. www.remotes.com has an original remote. Thanks
Hook up DVD
I hooked up my DVD player to the Yellow/Red/White inputs on the back of the set. I think you can buy a manual for $2.60 from the Orion website. Good luck.
Message on TV Error cannot access digital services
According to the specs on that model, it does not have a digital tuner capable of receiving ATSC signals. You need a converter to receive the digital signal and convert it to analog so that set can process it. Unless you already have a 'black box' between your signal source and the Orion, you have never received 'digital' signals.
S video
If your tv has S-video on the unit then yes you can plug it in from your S-Video out on your laptop. You will have to change the input on the tv. This will be done by hitting the TV/AV button on the remote, that is assuming this is an ORION stv2762. Otherwise it will be an Input, TV/Video, or AV button, or source . IF you have none of these then it could be as simple as pressing the Channel button down until you reach the AV channel. Make sure the laptop is on and then try changing through input's until you see the screen change to what the laptop shows. If you have more questions about this let me know.
A/V INPUT
You need to purchase either a replacement remote from ORION or Ebay, OR you can purchase a replacement universal remote and program it for your TV. Make sure the Universal remote you buy has an input or source button. Radioshack carries several for 8-15 bucks.
Orion stv 2750 27" TV
if you dont already have the remote set up then find the codes and t it up. the remote should have a button that says either tv/video or input. depending on the tv it should take you to a few channels through this button. look for either input 1 or 2, or even GAME. these should be the channels it will play on.
Top Orion Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
