Memorex MVDT2002 20" TV Logo
Posted on Apr 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black border with some channels
I would like to remove the 1-1/2 in border that appears with certain channels
Anonymous
Level 2:
  • Expert 201 Answers
  • Posted on Apr 07, 2010
Anonymous
Expert
Level 2:
Answers
201
Questions
0
Helped
69539
Points
599
if you mean the left and right sides of screen, look for a button on remote might be labeled several things, like picture size, aspect etc.. the borders pop up when you go to a non high def channel. some chs put borders all around the picture in those cases you won't be able to get rid of those.
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony
You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
There appears a black box on screens on certain channels
Hi, hit the cc button on your remote control untill the close caption display says off, this should eliminate the box from your screen
How to add a border in microsoft word office 2003
To add a border on a page, try the following:
  1. On the Format menu, click Borders and Shading, and then click the Page Border tab.
  2. To specify an artistic border, such as trees, select an option in the Art box.
  3. Click one of the border options under Settings. To specify that the border appears on a particular side of a page, such as only at the top, click Custom under Setting. Under Preview, click where you want the border to appear.
  4. To specify a particular page or section (section: A portion of a document in which you set certain page formatting options. You create a new section when you want to change such properties as line numbering, number of columns, or headers and footers.) for the border to appear in, click the option you want under Apply to.
  5. To specify the exact position of the border on the page, click Options, and then select the options you want.
If you'd like to add a border to a picture, text or webframe, just click on this link for further instructions: http://office.microsoft.com/en-us/word/HP051901201033.aspx
VS 7071
Do a hard reset or factory reset and it should work again
1helpful
Black Box on screen
By your description it sounds as though the closed captioning option has been turned on on the TV. Only certain programs are CC capable and that accounts for the box moving from channel to channel as some broadcasts are not CC CAPABLE. Go to the menu on the tv and ensure closed captioning is disabled. This should resolve the issue. If you need more help please let me know.
1helpful
Black box appears on tv screen
Check to see that you don't have any channel locks or parental parental permission measures deployed. If so remove them, this includes V-Chip, and Parental lock out on the remote, and check your TVs menu items. What channel are being affected by this problem? Give channel number and channel type.
Thank you,
Shuttle83
4helpful
Black screen keeps popping up
If a black box appears on the screen, and a small amount of the picture is visible around the border, it means that your closed captions are on and set to TEXT. Go back into the menu, navigate to the closed captions page and set the captions to OFF.
Black borders
Check the resolution settings on your cable box, you may have to call your cable provider to find out how to get into the settings menu, there is a stretch function in the settings that should make all the lower channels auto fit your screen, also see if there's a p=size button on your remote control, try pushing that when on the channels that have sidebars.
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
