Television will not respond to panel power switch or remote
I have a rapidly flashing green light on the timer botton next to the on off switch and the TV will not come on, This has been intermittent since I bought the TV for which pressing the reset button has always fixed the issue.....now the green light just continues to flash and resetting does nothing....TV will not come on???,,,,,I have unplugged the TV with no effect I can here the fans running inside the TV ect. Is the TV done for? It is only 5 years old.....could it be the lamp? Very little hours on this TV only used as home theater with DVD's, I'd say less than 250 hours on the TV
T TV is a MITUSUBISHI WD62525 Projection TV
Re: television will not respond to panel power switch or...
I have a Toshiba A 62HM95, and it appears to be stuck on standby mode. The green and red light are blinking at the same time. Is it an easy fix, or trash? Please help.Thanks
This unfortunately has become a widespread problem with this series of Mits televisions. You can read a forem about it here: Flashing green light of death
But there is hope, Mitsubishi has instituted a rebuilding program for the chassis inside of your television. Any authorized Mitsubishi repair center should know about how to get you set repaired. It's not cheap (expect $500-$600) and it takes a few weeks, but it will save your TV.
Press the System Reset Button which is on the RHS on control panel
If the TV fails to respond to the remote control, control panel
buttons, or will not power on/off, press the SYSTEM RESET button on the control panel.
The green LED on the front panel will flash quickly for up to one and a half minutes. When the green LED stops flashing, you may turn on the TV. Recent setting changes you made before using SYSTEM RESET may be lost.
If that fails try pressing and holding the menu button for 8 secs
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
SYSTEM RESET If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may turn on the TV again. Changes you made the last time the TV was On before you used the SYSTEM RESET button may be lost, however, the changes you made previously are not lost. POWER/TIMER Indicator The green light is a multi-function indicator. This light will flash rapidly for about one minute each time the TV is plugged into the wall electrical outlet, when power is restored after a power failure, or using the SYSTEM RESET button. Do not attempt to turn on the TV again during this period. Wait for the flashing to stop and the light to turn off, before attempting to turn the TV on. While the TV is powered on, the light illuminates steadily. If the TV has been programmed to turn on automatically using the Timer feature,
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
press and hold the tv botton on you dish remote till all the lights light up release the tv botton it should stay flashing then hit the larger of the two red power bottons next you will need to hit the up arrow one at a time till the tv shuts off when the tv shuts off you then hit the # botton at the bottom you wiil see the tv botton flash your code will then be saved
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
