Question about Maytag PAV2300 Top Load Washer
My washer stopped working.
I loaded the washer and started it. About ten minutes later, I noticed that the washer had stopped. I turned it off and on- nothing happened. I checked the outlet and it was still working. I pressed the button inside the lid with a screwdriver to make sure that wasn't causing the problem- nothing happened. My washer just stopped working and I can't find out why.
    Top Expert:
  • Maytag Master
  • 6,289 Answers
Maybe that lid switch. Really hard to say without a model # to see how it's designed.
Posted on Sep 21, 2017
5 Suggested Answers
Anonymous
SOURCE:
Anonymous
SOURCE: Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Posted on Dec 23, 2008
Anonymous
SOURCE: Maytag Neptune Tl Spin settings
HELP I HAVE THE SAME IS ISSUE AS\r\n
http://www.fixya.com/support/t1457953-maytag_neptune_tl_spin_settings
My Spin cycles keep cycling through, it seems to wash fine but is always beeping and changing through the spin selection.
Is it the control board, ribon cable, membrane??
HELP!
Nate
Posted on Jul 24, 2009
dh1200s
dh1200s
  • 335 Answers
SOURCE: My Neptune Tl FAV6800AWW will not go from rinse to spin
Failing at the 11 minute mark is the start of Spin Cycle and is key for clutch malfunction diagnosis see this post for a technicial description. The great folks at Maytag Eng. even hang out there dirty laundry in the Service Manual for the issue of a poor clutch design…. No pun intended….sure :). I could be in left field with my assumptions I’ve got to get my clutch to fail again due to those nasty sticky one-way roller clutches to be 100% dead on.
I agree with the other forum member solution, I own the machine and I feel this could be a clutch issue also. Check out the Tub Displacement Sensor with this check and make sure the transitions change the display from UC (unbalance closed) normal TDS position to UO to (unbalance open). Here is the test TDS Troubleshooting. You don’t need to disconnect the TDS from the Washer frame as I did just do the thru the lid check. Just make sure you pull and push down the tub as I described to make the tub excursions to test the Tub Displacement Sensor. I have not measured at CONN-P3 pin 11 to Control Board common but I believe a DVM would indicate apx +3VDC to +1.5VDC for the excursion limits to produce UC/UO to the LED display.
Here is the Service Manual for reference. Sears Parts Direct for reference.
If you are a DIY’er or have someone in the family with very basic mechanical skill sets take a look at this post and see if they can follow the clutch maint/repair/replacement process and save yourself some $money$. I would do this just to inspect the roller clutches in the clutch pulley for signs of a tub seal leak (slight to heavy rust). It’s a tight work area but I have hand very solid feedback from many forum members on this board and FIXITNOW.com for this step by step process.
The repair person did nothing wrong if he did not reseat the clutch properly on installation it would have spun off. I would drop the clutch out of the machine and inspect the roller clutches in the clutch hub and if your machine has the upper one-way roller clutch ring . How long has it been since your last clutch repair? I would not spend more than $60 a clutch pulley replacement part. This clutch pulley will work for all series FAV6800AW and FAV9800AW machines. Appliancezone.com keeps changing the link but here is the p/n punch it in their search box…. 25001169 …..
A repair tech that knows what he is doing shouldn’t spend more than 30 minutes in the house to pull the front cover off the machine remove the old clutch and install the new one. Some of the charges I see folks paying for a clutch replacement are out in left field. I hope you or a family member/friend can take this on.
Post back if you have questions or need help. Good Luck Rich
Posted on Oct 22, 2009
richroth
Richard Roth
  • 9472 Answers
SOURCE: I have a Kenmore washer
Sounds to me like the lid switch is bad. The timers hardly ever go out.
Here is a link to the part.
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Lid-switch-assembly-item-number-AP3100003.aspx
Posted on Nov 21, 2010
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
My washer washes for about ten minutes stops lights start flashing and it resets to like its starting over again and shuts off how can i fix this
Hi shaen1257 - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? With this information I can advise you further on what the main issue could possibly be.
Jan 12, 2013 | Frigidaire GLTF2940ES Front Load Washer
Washer will start and then stop 5 seconds later. It will start again 2min later and stop 5 sec after that?
I have a front loading frigidaire washer which works fine. It starts and stops throughout the whole wash but gets the wash done. That is how it works.
Does your machine simply stop and not finish the wash? Or are you concerned about the length of time it takes to get the wash done?
Aug 12, 2011 | Frigidaire Washing Machines
Losing pressure more and more often, especially
not quite sure where to get the parts, but if the pressure starts out ok and decreases as it runs, it is generally that the piston rings/seals are worn out, this can happen just from sitting up over the winter.
You can google Honda Pressure Washer Parts to find a supplier for the seals/rings
Jul 05, 2009 | Honda Garden
F-21 on my window
F21  mean LONG DRAIN if the dreain time ixceeds 8 minutes the water valve turn off. *After 4 minuts the "Sd" error will be do;[;aied tjem 4 minuts later the        F/21 error code woll be displayed. * Press STOP two times to clear the display.
if this wont work the following mus be done by a technician.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
The washer just stopped pouring water. Only faint humming sound.
Cool!
How 'bout a FixYa for the effort, and let me know if you need anything else.
Feb 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dribbling water when trying to fill up
Turn off faucets for hoses to washer. disconnect hoses at washer, noting which one went where first.. Hold end of hose in washer tub and turn on faucet. If it comes out strong, check the filter screens in washer inlet valve where hoses connected. DO-NOT remove these screens. If you do it can cause flooding by allowing grit to hold open valve. Clean screens without removing them by scraping with small screwdriver and flushing with water.
Nov 21, 2007 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
103 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
