This past friday there was a neighborhood water emergency and the water was shut down for several hours. When I started the washing maching i heard pressure release sound comming from the water source and since then I've had the following problem
Here is the problem : Water won't stop filling the machine and spin cycle does not automatically start.
1. I start the washer
2. It fills normally
3. The spin cycle will not automatically start.
4. The Machine will continue to pour in water and drain continuously -- it did this all night long on Friday.
3. Even when the door is open, water starts pouring into the machine.
Is there something I can do , without calling a repair person.
Thank you very much for your help.
If nothing else works, the washer door can be opened as follows:
•This must only be done in an emergency
if the machine's glass door does not open automatically when the program has finished.
•First check that there is no water left in the machine. If there is water left in the machine and it is not possible to run the Drain program, empty the machine by using the drain hose.
•Make sure that the main power switch is off and that the plug has been re- moved from the wall socket.
•You will find the emergency opener for the glass door in the double sealed bag.
•Open the glass door by putting the opener in the slot to the right of the lock on the door. Push the opener up or down and the door will open.
machine starts , goes through wash cycle will not empty or go to spin, therefore will not turn off then door will not open unless released by using manual pull at the pump/ needle catchment door
