Xerox Phaser 7700 Laser Printer Logo
Posted on Apr 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello, I have a xerox 7700 dx machine. Since moving the machine to new premises, when turning it on, I receive the error message, "Error 30 accumulator belt home position took too long" and it doesn't allow me to go any further. I have tried all the obvious things such as opening and closing drawers, doors, etc., turning the machine off and on several times. Any help would be much appreciated. Many thanks, Anson
Bob Wert
Level 2:
Scholar:
  • Xerox Expert 123 Answers
  • Posted on Apr 26, 2010
Bob Wert
Xerox Expert
Level 2:
Scholar:
Answers
123
Questions
Helped
90814
Points
272
The error is caused by the home sensor for the accumulator belt not finding the home position of the belt. Since the error occured after a move, toner probably contaminated the sensor. Use canned air and blow out the sensor. Manual @: www.lpscomputer.com/ec/Phaser_7700_Service_Manual.pdf
to locate the sensor. The other possibility is that the accumulator belt bit the dust. Parts a vailable at: http://www.lpscomputer.com/p-2993-1-016-1889-00-accumulator-belt-assembly.aspx
2answers
Onkyo DX-C390 6 CD Changer, display mech error
My dx-c390 is showing a "mech error" message, Onkyo DX ...
https://www.justanswer.com > Electronics Question
Jul. 30, 2017 - My dx-c390 is showing a "mech error" message, Onkyo DX-C390 6 disc cd changer, just started today...the door - Answered by a verified ...
DX-C390 is displaying MECH ERROR? - Q&A - Best Buy
https://www.bestbuy.com > site > questions > question
Jul. 28, 2019 - DX-C390 is displaying MECH ERROR? - Learn about Onkyo - 6-Disc CD Player - Black with 2 Answers - Best Buy.
my onkyo dx-c390 6 disc player is giving a mech error ...
https://www.experthelp.com > question > my-onkyo-dx...
Apr. 1, 2019 - my onkyo dx-c390 6 disc player is giving a mech error message. what ... Is there any error messages displayed on the display of the unit itself?
Error 14 scanner
That sensor is located in the developer housing. You can either replace the sensor, or replace the developer housing, which comes with the sensor. Either way, you will need to go into diagnostics and set the value of the new ATC sensor after replacement. (You will need to replace the developer powder if you get a new developer housing)
Xerox 7700. Paper is jamming at lower tray and bypass tray. Will print one page fine but multiple pages it stars jamming
Hello. The Error 11, polygon motor failure is usually caused by the motor controller chip going bad on the mirror motor. We found some of the contorller chips and had them replaced. The refurbished laser units can be seen at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
4helpful
XEROX PHASER 7700 ERROR 11
Error 11, laser unit polygon motor failure. If this fault reoccurs 3 times successively the 7700 . enter diagnostics and clear tech rep fault and clear this 09-380, 09-383.
2answers
Xerox phaser 7700 error 11
man...
listen .. you is with error
go listen cradle of filth the heavy metal :)
good bye
see you later
2answers
PHASER 7700 ERROR 30
try this
The following functions will generate a Tech Rep Fault:
  • Error: 30: Belt Home Too long
  • Errors: 12, 13, 14, 15: ATC-YMCK Sensor Fail
  • Errors: 40, 44: Fuser Main/Sub Lamp Temp Too High
  • Enter Service Diagnostics
  • Highlight NVRAM Access and press OK
  • Highlight Clear Tech Rep Faults and press OK
  • Highlight the Tech Rep fault to be cleared and press OK
If you have had the error 3 consecutive times , you do need to send the snippet to the printer to clear the error. The instructions how to do it are in the download.
Other things. You may need to replace the accumulator belt.
You may have toner backed up in the waste auger, you can clean that out and replace the waste bottle.
Cause:
The plastic tab attached to the cleaning blade assembly was broken, this tab opens the cleaning blade waste assembly when the belt is lowered .
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. The waste toner from accumulator belt cleaner could not reach the waste bin and jammed the augur. This caused the grinding noise by stalling the accumulator belt motor. This causes an error 30 code to be displayed.
The belt cleaner does come as a separate part 016-1889-00 and is very easy to fit and much cheaper than a new belt assembly.
Error 30 is a Tech Rep fault. After three Error 30's, the NVRAM Clear Tech Rep Faults will need to be reset to be able clear the Error 30 message.
1helpful
4answers
Error 3-397 Xerox DC 12
Hello, I have a Xerox DC 12 and i receive the error 3-308
Someone can you help me or information about me ???
Thank you.
Ram Error message
Have you tried reseating the ram?
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
