Estate TT21AKXKQ / TT21AKXKT Top Freezer Refrigerator Logo
Posted on Mar 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Estate TT21AKXKQ Refrigerator Leak
Have a leak inside the refrigerator, seems to be dripping from the freezer. Drips down onto top shelf of refrigerator, drains to back of refrigerator and ends up filling the bottom of the refrigerator under the storage bins.
  • 3 more comments
  • Anonymous May 04, 2008
    have fr 526zr6 side by side water drips down inside freezes bottom storage rack. Also water tube from outside to ice maker freezes up all the time?
  • khinchcliffe Jul 21, 2008
    My refriderator leak some time pours where I have a container and paper towels on the top shelf under the holes. I sometimes have to get ice off the inside of bottom of the freezer. How do I fix?
  • lraley Jan 28, 2009
  • tinasatterfi Mar 20, 2009
    leajing water and not cooling at all
  • Anonymous Apr 16, 2009
    Water is leaking down onto the shelves in my fridge. For months now I've had to avoid putting any cardboard/paper packaging in my fridge for fear of it sopping up all the leaking water. I believe the drain pipe from the freezer to the drain pan underneath the fridge is frozen. We unplugged the fridge months ago and thawed it out with a hairdryer but the pipe was frozen again wthin a couple of days. Please help.
Ron Coons
Level 3:
President:
  • Estate Master 2,651 Answers
  • Posted on Mar 18, 2008
Ron Coons
Estate Master
Level 3:
President:
Answers
2651
Questions
Helped
1547499
Points
7824
Sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
1helpful
I have a top freezer that drips water in front of the refrigerator door. Could it be bad gaskets?
If it drips down the front surface of the door, it could be two things. Either the gasket to the freezer isn't sealing properly or the heater in the door frame has failed. It should feel just warm.
Leaks inside are a blocked or partially blocked defrost drain.
Water is accumulating in the bottom of the refrigerator
Do you see it dripping from the top of the fridge compartment? You probably have a clogged drain.
Where is the freezer drain line; it is frozen and dripping into the bottom
It is inder the floor of the freezer...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
5helpful
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
4helpful
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
1helpful
Water leaking in refrigerator on shelves, drawers, and under draw
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
8helpful
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
2answers
Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Top Estate Refrigerators Experts
vince
Sean Wright
Sean Wright
MasterTech
MasterTech
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
