This is a regular Amana dryer, NOT a washer/dryer combo.
I noticed the last couple of weeks, it is taking longer to dry the clothes.
Yes, the filter is clean.
Can you help?
Thanks
In all occasions it is important that your observation
is most important and so is vital to the identification /rectification and
solution. If you have noticed that water has leaked then as the drain hose
pump/valve and fittings are located on the underside of the machine it is
important that you look for possible leaks here. In some cases the drain hose
would be clogged at the drain end to outlet of the house and so there will be
back flushing resulting in overflow to the outside. Also the drain pump/valve
can be clogged or the drain hose clamps can be loose on the grip which can all
cause the leak to occur. Removing and cleaning the drain pump/valve, tightening
of the hose is also very important. Also water can leak if there are gaps on
the front door gaskets and must be checked but this will happen only during the
cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing
Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
In Stock
Quantity:
http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Having same problem. Taking forever or not at all to dry clothes. Vent CLEAN. Even took back vent off. When I did so about 2 tbs of water ran out. Whats up?? You suggested that heating element has gone faulty or tripped out. What does " Tripped Out" mean??? Is there a fuse/breaker to the heating element. Don't know if this has anything to do with anything, but our electricity has been going on & off with all the high winds this winter and spring - Thanks
I have a Whirlpool Duet dryer that is 4 years old and it's leaking water from the rear. Sometimes the clothes are dry, sometimes they're warm, but wet. Any ideas?
