Washing Machines Logo
Posted on Apr 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 131
I have an error code 131 on my fisher and pyakel washing machine, how do i fix it? Its a 5kg top loader smart drive 085 if that helps any.
electronic & computer repair& servicre
Level 3:
  • Fisher and P... Master 12,061 Answers
  • Posted on Apr 08, 2010
Level 3:
Answers
12061
Questions
0
Helped
4006185
Points
36390
Paul P
Level 2:
Filmmaker:
Uploaded 5 video answers.
Scholar:
  • Fisher and P... Expert 80 Answers
  • Posted on Feb 27, 2019
Paul P
Level 2:
Filmmaker:
Scholar:
Answers
80
Questions
0
Helped
61395
Points
218
This video will help with error code 131 and 130
https://www.youtube.com/watch?v=pUrtHJ-1kPI
Kelvinator 085 Smart Drive. Why won't it start?
kelvinator smart drive 085 washing Questions & Answers ...
www.fixya.com > Forum > Tags
smart drive 085 not filling with water when start button depressed Could be the magnetic latch on the lid that tells the machine when its closed you can by pass
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
1helpful
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
1helpful
My fisher paykel top loader smart drive 053 has started to sqeak when spinning
drive belt may be loose and squealing just like a car will suggest re placeing it at that age.
1helpful
2answers
I have a fisher & paykel aqua smart WL26CW1. I just replaced the module. I am now getting an error code of 9. What does that mean?
Hi dear.That's related to size error.When you replace the motor control module you need to set the machine wash capacity like:5Kg or 7.5Kg.To do that please follow the steps: Phase 1 to 6 Size Switch Error
The Display size switch setting does not match that stored in the memory.IW machines, Phase 5 and 6
To access Size Setting Mode. Push and hold the Fabric care button and then press the Power button to enter Size Setting mode. Select the correct size on the display by pushing the White button next to the correct size (phase 5) or using the Adjust button to highlight the right size (phase 6). Size setting is then achieved by pressing the Power button. Powering off will set the size into the memory. Check the size is set before starting a cycle.
I hope that helps.Thanks.
Fisher & Paykel Washing Machine Smart Drive 085, 5kg. I put clothes in, then detergent (liquid), then turn on machine. But with lid closed, all taps on, all connections ok, washing machine does not...
Close your external inlet valve to the machine. Disconnect hose of washing machine from the valve; keep a bucket there and open the valve to see if water comes well. Next check the screens (filters) on the hose, clean well. This shd be done on both ends of the hose/s. Refit carefully. Check for leaks. If water still (don't forget to open the valve!) does not enter machine change the inlet valve of your wash machine. Can be done yourself. Rate me pl...........if helped.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
