Question about LG WM2688H Front Load Washer
I don't seem to be getting Hot water to the LG Front Load washing machine.
    Top Expert:
  • LG Master
  • 10,627 Answers
Possible hot feed calcium build up in filter
Posted on Sep 03, 2018
    Habit-Forming:
    New Friend:
  • 15 Answers
AK Techno Service is one of the best http://aktechnoservice.com/lg-washing-machine-service-center-in-hyderabad/ . Front load top load semi-automatic drum failure, PCB repair service etc.
Here,you can find any type of solutions for your LG Washing Machine.
I don't seem to be getting Hot water to the LG - b72bed06-5439-421e-8bf7-379e0ff4e9a1.jpg
  • LG Master
  • 12,061 Answers
6ya staff
SOURCE:
Anonymous
  • 378 Answers
SOURCE: my whirlpool front load washing machine accept hot
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Posted on Apr 03, 2009
skotkolr
Scott Hill
  • 558 Answers
SOURCE: Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Posted on Apr 07, 2009
localwonder
Michael Masters
  • 6784 Answers
SOURCE: LG WM2355C water leaking under machine after washing finished.
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Posted on Jul 23, 2009
hotpoint jon
  • 353 Answers
SOURCE: LG front load washing machine - need to replace drain hose
It's jusy one clip go in from the bottom
Posted on Mar 20, 2010
nomess
  • 343 Answers
SOURCE: my LG front load washing machine is reading OE...
oe is drain error, which means that the machine is slow/or not emptying..Most likely you have to clean the pump filter...This is accessed via the small door at floor level..Unscrew the pump cover andclean the filter...Remember that any water will drain from the machine from here, unless the machine is empty...Leaning the machine back can help...Good luck...Nomess
Posted on May 22, 2010
Just put in a new drain pump in LG front load washer and now I don't get any hot water. All the hoses are hooked up correctly. Is there something inside the unit when put back together that can bu
the drain pump does not effect the hot water intake that is or has to do with the water inlet valve , the coil may be bad or clogged try switch the hot and cold hoses and see what happens
some pumps do have an electrical connection? be sure to check for loose connection
other wise test with a meter
Feb 08, 2013 | LG WM2487H Front Load Washer
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
My washer wm2277h does not have cold water just hot water..Can someone please help me
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 23, 2011 | LG WM2277H Front Load Washer
What is problem code IE and how do I fix it on my LG front load washing machine?
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. if this doesn't help then there are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly. wm_inlet_filter_removal(1).jpg
Hope this helps.
Mar 09, 2011 | LG WM-2277HW Front Load Washer
LG Front loader humming, not filling with water, or operating
its not the filter problem.the motor is faulty and that needs replacement. you can get motor at  www.repairclinic.com to avoid circuit board damage do not try to on the machine again n again till the motor gets replaced as it can short circuit the main board too.
May 06, 2009 | LG WM2487H Front Load Washer
Cold water Washes
Apr 07, 2009 | LG WM-1832C Front Load Washer
No water geting into washing machine.
check hot and cold inlet vavle with meter...do you fell them humming,,or vibrating...
Jan 02, 2009 | LG WM-2277HW Front Load Washer
Not able to do hot washing
My LG Toploader (wft753a) has a cold and a hot inlet, and the mechanism inside the machine simply turns the flow from each tap on and off. There is no internal heating element in it.
Nov 22, 2007 | LG WFT1071TP Top Load Washer
LG WM2688H Front Load Washer Logo
711 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
