LG 37LC7D 37 in. LCD HDTV Logo
Posted on Apr 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What brand USB Wireless Adaptor will work with my LG TV
What brand USB Wireless Adaptor will work with my internet ready TV model LG 47LE5500? I just want connect to my existing wireless home network.
Thanks
Anonymous
Level 3:
President:
  • Master 3,085 Answers
  • Posted on Apr 08, 2010
Anonymous
Master
Level 3:
President:
Answers
3085
Questions
Helped
1006932
Points
9738
Any brand of USB Wireless Adapter will work. Netgear, Linksys, etc
  • 1 more comment
  • valentine120 Dec 04, 2010
    I tried a Belkin Wireless USB Adapter and the tv screen said it was not compatible.
  • Hurryharry Dec 07, 2010
    You will have to buy an LG COmpatible wireless adaptor. This is because your TV cannot install the driver for "any" other wifi adaptor. In amazon it is currently 41$. Pls chk.
  • nigeldean May 07, 2011
    This is incorrect as the TV will not recognise other adaptors as the drivers are not installed on the tv
How to connect my lg 55le5500 tv to wifi
via the user manual page 60
https://www.manualslib.com/manual/645323/Lg-Lcd-Tv-Led-Lcd-Tv.html?page=60#manual
and you need to have a wi fi network in your home .
and you will need to know the wi fi encryption key
and you need LG Wireless LAN for Broadband/DLNA Adaptor
internet search for EAT60713302
As the original lg wireless LAN for Broadband/DLNA Adaptor seems to be discontinued by LG
and the EAT60713302 is coming up in many search results
My Dell Inspiron 560 suddenly stopped connecting to internet through cable-modem.
Onboard adaptor hardware failure? Or is it missing Drivers?
Wireless adaptor - did you install drivers for adaptor? Did you check that WiFi on the adaptor is switched on?
On a side note: I've found that USB 2.0 Wireless N adaptors are the best for connectivity, as they have their drivers on the adaptor, are fully plug and play (Vista/7/8 and even some models on XP). I recommend Transcend (brand name).
I've upgraded the FW on my LG 47LE5500 and now the TV is not succeeding to start - looping reboot
Ur tv Firmware u upgraded it have corrupted files or the wrong version.Sorry ur main board tv Tuner signal board it have corrupted in it softwares or the wrong version in it CPU programming now.This problems,u cannot be undone or put the old version back.Only can repair by doing replacing a whole refurbish new tv Tuner signal board only now.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main board tv Tuner signal board for the replacement.
I changed my router from an old Linksys WR54TG to the Netgear N router and the ANWF100 still will not work! It sees the AP but I after 15 attempts I keep getting Connection Failure. Netgear says that I...
It sounds like the dongle has a problem. You should consider returning it for exchange or refund.
I found this page on amazon.com - scroll down to bottom to read reviews.. They say easy to install, and work great. One caveat, will not work with older model same tv.
http://www.amazon.com/LG-AN-WF100-Wi-Fi-USB-Adaptor/dp/B003F9HH2W
Worth reading.
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
http://www.lg.com/us/tv-audio-video/televisions/LG-led-tv-42LE5400.jsp
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
1helpful
My recently purchased LG 32LD550 TV is wireless ready. I purchased a LG AN-WF100 USB adapater but the wireless control input on the TV is of a different configuration. It seems to be a smaller connection...
The wireless control input on the back of the TV is not is not for a wireless adapter. It is used to connect a wireless media box, which you don't have. I have the same TV and use the wireless adapter. You want to plug your LG AN-WF100 into one of the USB ports on the left side of the TV.
1helpful
Netgear WG111 USB adaptor does not work
-- check the device manager of your computer
-- for win xp - go to right click on my computer - manage - computer management - device manager - on the right hand side that the netgear adapter is listed under network adapters or other devices
-- check the status that its working properly
-- then upgrade the latest drivers ...
-- follow the link ::
http://kb.netgear.com/app/products/model/a_id/2556
and try to connect ..
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
