Power light blinks and then TV shuts down. Also, there is a black 1 inch line from top to bottom in the middle of the screen. TV is only 2.5 years old and we watch very little. What is going on. Is my TV dead?
AS I was watching TV the TV shut down suddenly. When I checked it out the power light was blinking and the Tv refused to start. I disconnected the power and waited a few minutes. Then restarted. The Tv information was completely erased and I had to re put all the info, such as date, time etc. After starting it, there was a very thin colored line in the center of the TV. around the colored line about an inch on either side going from top to bottom of TV it is dark. The picture is cut in the middle. After a few minutes the TV shut down again and the start light button started blinking again.
TV is Panasonic TH-58pe75u. It is 2.5 years old and used lightly. If you think you know what the problem, what is it and how much should it cost to repair, and is it worth repairing?
The TV cost about 1800 bucks.
display ic failed, it need a replace ment,,, contact the vendor from where u purchased the tv. they will send there expert personnel, he'll replace the ic,, if your t.v is under warranty, then this will be replaced free of cost,
