Computers & Internet Logo
Posted on Apr 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need wireless receivers for the following items. Can you tell me if they are available at your store thanks 4 Wireless keyboard 700 silver QWERTZ - no receiver 2 Wireless keyboard 700 (v1) QWERTY - no receiver 2 Wireless multimedia keyboard 2 x QWERTY - - no receiver 1 Wireless multimedia keyboard 1 x QWERTZ - - no receiver 1 Wireless laser 6000 QWERTY - - no receiver 1 Wireless desktop elite QWERTY - - no receiver 2 Digital media keyboard QWERTY - - no receiver 1 Wireless keyboard 3000 QWERTZ - - no receiver 3 Wireless keyboard 6000 (v3) QWERTZ - - no receiver contact paul freeman [email protected]
wwlvictoria
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,001 Answers
  • Posted on Jan 17, 2017
wwlvictoria
Master
Level 3:
Renaissance:
Answers
1001
Questions
0
Helped
603641
Points
6027
  • Excellent Bluetooth Receiver,stable connectivity and remarkable signal stability.
Amazon com Charm sonic Portable Bluetooth 4 1 Receiver Wireless Multipoint...
Anonymous
Level 3:
  • Master 1,851 Answers
  • Posted on Apr 09, 2010
Anonymous
Master
Level 3:
Answers
1851
Questions
Helped
513077
Points
5186
tip
Wireless keyboard and mouse
Most problem with the wireless keyboards and mice are one of them is not responding or not connecting to the wireless USB adapter that's connected to the computer, here are the things that you may do:
1. Make sure to use fresh batteries.
2. Verify if the keyboard and mouse are turned ON.
3. Avoid putting any possible wireless interference such as base of a cordless telephone and cell phones.
4. In pairing up the keyboard or the mouse, try pressing the connect button on the USB wireless receiver followed by the connect button on the wireless keyboard or mouse.
5. If that did not help, then hold down both connect buttons (on the wireless receiver and on the keyboard or mouse at the same time for five (5) seconds and then release them both).
The keyboard or the mouse should connect to the USB receiver. If same problem occur, then the device needs repair.
on Dec 01, 2009 • Computers & Internet
1helpful
What's the prices/rate of Microsoft wireless optical desktop receiver 2.1 model 1028, Microsoft standard wireless optical mouse model 1025 and Microsoft wireless multimedia keyboard 1.1 model 1014
Microsoft wireless optical desktop receiver 2.1 model 1028 - varies from Rs. 1900-2200
Microsoft standard wireless optical mouse model 1025 - varies from Rs. 400-600
Microsoft wireless multimedia keyboard 1.1 model 1014 - varies from Rs. 700-900
3helpful
I have a microsoft model 1011 wireless keyboard with no receiver. Is there a receiver available to make it work?
I find alot of wireless microsoft and logitech keyboards at thrift stores,also mice. Every microsoft keyboard I bought works with my microsoft receiver. Same with logitech. Try looking in the thrift stores for your receiver, or go on ebay. Both will have great deals. I buy keyboards for 5 and 6 dollars!
My mouse work but not my wireless keyboard
Hi, 3 items top choose from ...
1) There is a sync button at the base of the wireless keyboard and the wireless receiver. Press the button on the wireless receiver and then on the wireless keyboard. They should now sync. and your keyboard should then function.
2) Most likely that the drivers for the keyboard may have been updated when your pc does windows update. You may need to re-install the drivers for the wireless keyboard
3) reboot computer.
Good luck .. hope this helps.......
My son moved the dell wireless keyboard and mouse from our home computer to use in his room now I cannot get it to work on our home computer again. Help
Please follow the bellow steps to setup the wireless mouse and keyboard again.
1) Check whether the batteries are working in the both device.
2) Connect the 3rd kit with the PC in the USB port (receiver).
3) Press the knob for wireless activation on the receiver along with the same of the keyboard (back side of the keyboard) for 4-5 seconds. It will activate keyboard.
4. Now press the wireless knob of the keyboard as well as of the mouse - mouse will start to work along with keyboard.
Hope the solution will work fine.
Thanks for using FixYa.
Microsoft wireless keyboard 700 v2-0 not working
Your keyboard MS 700 v2.0 needs a USB receiver to work. They are pert of set. You may also have a wireless mouse MS-700 that is also part of this set.
1. Do you have the receiver ? This has a USB connector that must plugged in to your PC's USB port
2. Are the batteries in your keyboard dead ? If so change them for fresh ones
Then proceed with the instructions in the Quick Start Guide which can be found from this webpage
Microsoft Hardware
Note the light on the receiver only flashes when you press the 'connect' button. At all other times it is normally out. There usually no lights on the keyboard. You should not need extra drivers as they part of the OS if you are using Windows XP or 7.
If you still have problems see
Your wireless mouse or keyboard does not respond or you receive The...
or search on the internet for our specific case
8.March.2015
WIRELESS KEYBOARD caps and niumber lock status
The MS Keyboards and Mice 700 v2 receiver has a reset Button under the word "Microsoft" press this button and then while its flashing press the connect button under the mouse! ALL Fixed
2answers
Connection problem
You will have to have the wireless receiver connected to the laptop. If your laptop has a bluetooth receiver built in, you could get a bluetooth keyboard and mouse. They also make small bluetooth receivers that plug into a USB port.
I hope this helps,
Eric
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
To determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Grand Canyon Tech
Grand Canyon Tech
