Router D-link DIR-615
Os windows Xp home professional service pack 3
link sys USB adapter
Medion 86097
SSID - FRONT ROOM created in Router
Trying to set up in Station mode
Scan does not find FRONT ROOM
when choosing strongest signal from the list provided Medion software shows disconnected
lights on medion 86907 power, wireless, lan
please advise on resolution
SOURCE: connection problem between modem router and hub
Sounds like you may need what is called a "Crossover Cable' connecting your router to your hub, or if either device has an uplink port, use it on one device to connect to normal port on other device. Here are instructions for making your own cables: http://www.lanshack.com/make-cat5E.aspx
SOURCE: WiFi unable to connect/maintain connection
Hello b... couple things.
First; see if going into Control PanelNetwork Connections and disabling the wireless network connection, then enabling it again fixes it. If it does then you have a work-around...
Second; there was a Realtek driver update offered by Windows Update. If that has
been installed (Control Panel-Programs and Features-View Installed Updates)
roll it back to the previous driver through Device manager and get the
update direct from either Toshiba or Realtek.
See if that helps.
This seems to be happening with that Wireless card and Vista... let me know what happens please.
SOURCE: D-Link DGS-2208 only works through Hub uplink but not router?
i think it it ehternet cable problem.
when u connect switch to swith it is twisted pair but when u connect router to switch then straight.
SOURCE: Can't connect to my router anymore (WEP encrypted).
Hi deray953,
First we need to remove the previous profile in your wireless network. I believe you know the SSID for wireless connection using WEP security. You can check this by going to;
Using Windows XP SP2/3
1. "Control Panel" > Switch control panel to classic view ( look at the upper left side ). > Double click "Network Connections" > Right click "Wireless Network Connections" > choose "Properties"> Click the Tab "Wireless Networks" ( middle tab) > go to the list of profiles and remove the Wireless name or SSID for your home connections. > click OK and Close the properties of wireless.
To reconnect again, you need to know your WEP key or network key for wireless connections if not, you can do this procedure...
1.Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
d. Click on the Wireless Settings under Setup.
e. take note of the KEY 1 ...that is your WEP key..take note of it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
SOURCE: Using a HN9000 modem and D-Link dir 615 together
change your routers IP address to IP address. 192.168.1.1.
