Hello!
Problems with monitor Sony SDM-HS73.
The monitor is about 7 years old.
Now i have a problem with Power Supply Board with Inverter
part number = 6871TPT237G.
I discover PCB board and found two faulty
smd HEX FETS = IRF7389.
Also the E2 diode was burnt.
There are 4 HEX FETS on the pcb board.
One of them was burnt very much and damage the pcb also.
Looks like it was very hot.
I replaced all 4 HEXFETS with new one, also diode E2
and all electrolitic caps on PCB board.
I check all and put components together and monitor
starts fine with no problems.
LCD back light works OK.
After two days, the same two HEXFETS short
circuit again.
Looks like something is overheating and
damage the HEX FETS.
Have anyone the same fault and find solution?
Probably i must replace complete G board.
Janez from Slovenia
At this point you may have bad transformers, bad tuning cap, you need to check the frequency of the inverter oscillator to see if both of them are running at the same frequency, the bad one may not be. The Inverter/power supply is not made by SONY, Powernet makes the board. Please see what went wrong with the one I fixed.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
One thing to keep in mind, when the board turn into carbon (blacken), it will conduct. The circuits operate at high voltage and high frequency.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
