2 ways you can do this. <br />
1. Connect to your router 192.168.1.1. Go to advance setup, NAT settings, then virtual servers. Click ADD, you will be at a setup screen now, click Select Service and choose xbox live. Then type in your ip address just below (192.168.1.1) and click save/apply, thats it.<br />
2. Go to this site, <a href="http://www.portforward.com">www.portforward.com</a>, go through the motions and selct your zhone 6218 modem. Follow the directions they have listed.
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection
through control panel > network connections.... if you get the ip
adress in the range of dlink router then try going to start > run
> type "cmd" and hit enter >command prompt will appear... in
command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
try doing a Google search USUALLY the address is 192.168.1.1 if your running xp or higher look for the command prompt icon it is in the start menu under acessorys the type ipconfig it should give you a number for your gateway or call up the manufatures tech support
Foildemon, If you are still needing assistance with any of your Consolidated Communication services please contact our tech support staff at 1-800-480-0080 opt 1. We are available 24 hours a day 7 days a week for your convenience.
hi Jeffkrick.
if you go to the link you can read the manual.
when you open this link you will see the pages at the top of the page just click on the pages and it will let you read it. Zhone 6218 I2 User Manual
The manufacturer won't have your installation CD because that process is exclusive to your ISP. Check your ISP's website to see if they release their setup software online or contact them to get the required CD.
