Question about Candy Washing Machines
My hoover washer dryer VHD is showing a fault E11 and the washing in the machine is still wet
  • 155 Answers
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
6ya staff
SOURCE:
I have a hoover vhd 9163zd with error code E05,what component does it refer to being at fault,where is the component located
Error Code 05 is a NTC fault, either open circuit or shorted.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "E05" error code will be displayed.
Possible Causes / Procedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this model. (abnormal = infinity).
Replace failed component. It could be the sensor or the temperature control module (NTC module).
Good luck.
Apr 20, 2015 | Hoover Washing Machines
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Hi I have a hoover vhd 9143 zd washing machine which went 'pop' today. Now it doesn't work and the red digital display does not work properly? Any suggestions?
unplug the unit then remove the cover and look for the circuit board which get wet.or a wiring that get loose connection.
Oct 15, 2012 | Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
Dec 20, 2010 | Washing Machines
Error code E11 on hoover washer dryer vhw854d
Error code E11 is a dryer thermostat problem. The wiring, by design, is too short, and secured too tightly up and behind the digital display, and extends to a connector located on the machine's drum housing. When the machine is in motion, and there is a degree of drum movement back and forth, left to right, the wire disconnects resulting in Error code E11. Your issue may be that the wire is loose, and not fully disconnected (yet) hence the fault being intermittent. Error code E11 requires a service engineer to reattach the thermostat wiring in a way that allows for the drum housing to move, as per it's design, without the wire being disconnected from the drum housing connector, when the wash load becomes unbalanced during the wash cycle.
Nov 12, 2010 | Hoover Washing Machines
My hoover washier dryer has stopped heating up. I works ok as a washing machine but the tumble dryier doesnt heat up. It is a hoover vhw654d washier dryier
on all dryers you have a hi and a low relay as well as the heater and in some you even have a run tstat check that you have continuity on each side of each of your relays as well as your heater any of these pieces that does not have continuity would be the one that u wuld replace hope this helps if you are not electrically inclined plz call a technician
Jul 21, 2010 | Hoover Dryers
I have a Hoover vhd sensor Dry Washer Dryer and its come up with error E11. Can you help ?
Hi I had the same problem about once a week and every time it happened I had to turn off the washer off and leave for a while and start new wash cycle. It worked for a while but eventually it started to throw E11 once I put it on (not the middle of cycle it used to do). I had to result to call the repair man. He checked all the hardware and nothing was wrong and re-install the program on the board and it stopped throwing errors. After 4 month of problem free period, it gave me E11 again today though..
Jun 23, 2010 | Washing Machines
I hav a washer/dryer - problem is: the clothes weren't drying properly and then 2 day when I used it just on the washing cycle, the clothes came out really wet.
Suspect machine is not spinning correctly , check drain outlet filter and/ or pump. Otherwise may be electronic fault , needs an engineer if so .
Nov 01, 2009 | Hoover AAA160 Front Load Washer
Washing Machines Logo
2,436 people viewed this question
Top Candy Washing Machines Experts
peter gittos
peter gittos
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
