Some unlock codes for Jwin DVD players are:
Jwin JD-VD100 / JD-VD703 / JD-VD753
1. Press SETUP
2. Press PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER, NEXT CHAPTER, PREV CHAPTER
3. "VerX" is displayed (X=RC)
4. Select the RC with RIGHT and LEFT (255=Codefree)
5. Press RETURN
Jwin JD-VD120
1. Press SETUP
2. Press 1, 3, 6, 9
3. Current RC should be displayed
4. Select RC with UP, "DOWN" (0=codefree)
5. Press ENTER
Jwin JD-VD130
1. Method 1:Press SETUP
2. Press 1, 3, 6, 9
5. Press ENTER
1. Method 2:Open the disc tray
2. Press PROG
3. Press ENTER 3 x
4. A menu should appear.
5. Select RC with UP, "DOWN" (0=codefree)
6. Press STOP
7. Close the disc tray
Jwin JD-VD135 / JD-VD147
1. Open the disc tray
2. Press SETUP
3. Press 1, 3, 8, 9
4. Use Up/Down keys to change the region
5. Press SETUP
Jwin JD-VD140 / JD-VD501
2. Press 2, 8, 1, 2
3. Use the arrow keys to change the region (9 = multiregion)
4. Press SETUP
5. Close the disc tray
Jwin JD-VD145
2. Press 9, 7, 3, 5
3. Change the region
Jwin JD-VD200 / JD-VD203 / JD-VD500 / JD-VD503
1. (Open the disc tray)
2. Press SETUP
3. Press 1, 3, 6, 9
4. Press LEFT 3 x
5. Press RIGHT
6. A new menu entry appears (Version)
7. Select it and select RC (0=codefree)
Jwin JD-VD138 / JD-VD504 / JD-VD602 / JD-VD603 / JD-VD745 / JD-VD903
no known hacks
or you can try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
no da acceso a netflix
