You shouldn't have to loosen anything. There should be an idler pulley. It will be a spring loaded pulley which keeps the belt tight. To remove your belt, once you locate pulley, release the tension by using a socket and pull/push untill belt loosens, (with 2 people is easier) MAKE SURE YOU KNOW HOW TO PUT IT BACK ON!!! Go online, or factory, and get a diagram of belt routing.
Look for a tensioner pulley. It's spring loaded to maintain tension on the belt. It's a pulley that does not spin a device like alternator, power steering pump or AC compressor. If you put a wrench on it and push it one way or another you can overcome the spring tension and the belt will just pop off. Check the belt routing diagram under the hood when you reinstall a new belt. It should identify the tensioner pulley, sometimes known as an idler pulley.
Below is the master help link
provided to go through belt routing diagram:---Timing belt, drive belt,
serpentine belt, accessory belt, fan belt, engine belt routing diagrams for all
types of car models?
Click the link below: ----
http://carbeltrouting.blogspot.in/2012/02/timing-beltdrive-beltserpentine.html
----------This will help. Thanks.
