You've set the keylock feature on your walkie talkie. From the Uniden manual...
KEYLOCK
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
KEYLOCK
Mostly all nokia phones have a full phone lock along with a keylock. To enter a security lock, you need to activate it first. for this, go to your settings-> phone settings and scroll down to security keyguard. Then switch it on in case it is off. Note: in case your phone locks at this moment, the default keylock is 12345 to unlock After this you need to put in a new password to the security keylock For this, Go to Settings-->Access codes--> Change Security code Enter the default keylock i.e. 12345 . Then enter a new password which you will remember. Verify it by entering it again. After you have done this, go back to settings->phone->Automatic Keyguard Switch it on and enter the time for the keylock ( can be 5,10 or 15seconds depending on your choice) After all this is done, you are good to go. Just remember your passcode.
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
You
can manually lock the keypad to avoid pressing keys by accident. You
can still answer an incoming call and the keypad will lock again when
the call is finished. The keypad remains locked until you unlock it
manually. Depending on your phone model, you can activate the
automatic keylock. When the automatic keylock is activated, the keypad
locks shortly after you stop pressing keys. Please note: with
some phones you can still use external keys when the keypad is locked.
If you wish to lock the external keys you must lock them separately.
You can manually lock the keypad to avoid pressing keys by accident. You can still answer an incoming call and the keypad will lock again when the call is finished. The keypad remains locked until you unlock it manually.
Depending on your phone model, you can activate the automatic keylock. When the automatic keylock is activated, the keypad locks shortly after you stop pressing keys.
Please note: with some phones you can still use external keys when the keypad is locked. If you wish to lock the external keys you must lock them separately.
had the same problem w/mine. pull cover off shifter, there is a lever there that gets guked up. lube well and work it manually till it frees up. it took mek a couple of days and a can of pb blaster.
