You can fix one of two ways.
1/ replace the cold water solenoid valve
This is located directly behind the cold water hose fitting
at the top of the machine
Remove the small electrical control panel by removing the
three small screws.
2/ If you only need the cold wash program you can save
money by swapping the vaves around. They are easy to
remove and they are held in place by a plastic insert which
lifts up to remove them .
Make absolutely sure that your Machine is disconnected from the mains supply before you replace these valves
Regards
Bill K
Tuart Hill
WA
I don't have a solution but would love a photograph of the dials on a 200M showing the labels for the settings as mine have worn away.
