Washing Machines Logo
Anonymous Posted on Mar 18, 2008
How do you open a Kenmore Elite Oasis top-loading washer?
I'm getting error codes when starting the wash. It gives F1 and stops the wash, stopping and restarting several times will usually work.
Diagnostics then show F68 and F41 codes.
The best I have found online is that it may need a new control unit - electronic control. I've ordered one, but I can't find a way to open the washer. Any ideas?
  • 1 more comment
  • Anonymous Mar 27, 2008
    RESOLVED MYSELF
    Three long screws behind the control unit "hood", in back of the washer. Lifted up the hood, and there was a black box - the electronic control. Unplugged all the wires, took the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wired everything (it shows what wires go where on the electronic control box). No more error codes!
    The electronic control was $146 + S/H.
  • yguo789 Jul 19, 2008
    I have Kenmore Oasis washer. Right after you push start button, it showed F1. After several time stop and start cycle, it started working. But usually will stop again, when wash cycle reach to "rinse', IT STOPPED again, and showed F1. I have to skip rinse to spin and drain, then it can finish the cycle.
    What's problem and how can I fix it.
  • Anonymous Oct 29, 2008
    Where did you order the control board?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1833
Points
I just finished installing my new control unit for my Kenmore Oasis and my F1 problems are GONE! I ordered it from Sears Direct Parts. With shipping and taxes it came out to about $174 for the part, but our issues are gone and now we can wash a load of clothes without having to reset it several times.
Can wash my clothes washer is giving a f1 announcement and stops.is a kenmore elite oasis model 110.27032602 quiet pak 2.thanks
The F1 error code means that the control board has a detected a problem within the control itself and the control board would need to be replaced.
The part number for that control board is W10189966 it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
1helpful
F1 error
yep electronis control board in the console is bad.
10helpful
2answers
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
1helpful
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Kenmore Elite Oasis Washer Error Code F1
per sears unplug the washer for at least 10 min then plug back in and push pause or stop 2 time.
1helpful
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
1helpful
Kenmore Elite Oasis HE/ Error Code F1
Ok these are not the series 70, getting a model number off the door will reallllllly help. Some of these sound like the oasis. F1 is motor control or primary control failure and F 41 is a rps thermistor failure.
For the guest with the 11027086601 kenmore elite oasis here is a link for supplying me with a partial model number, much thank yous!! paste in a browser:)
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11027086601&productCategoryId=0153200&brandId=0583&modelName=RESIDENTIAL WASHER&diagramPageId=00002&componentDescription=CONTROL PANEL PARTS&documentId=K0601003&backToLink=Return to Sub Components list
Top Washing Machines Experts
john h
