2004 Kia Rio Logo
Posted on Apr 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the slave cylinder on a 2004 kia rio?
Anonymous
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Apr 11, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
60
Questions
Helped
21702
Points
187
Should be on the front side of the transmission, where the trans and engine connect. Follow the line from the master cylinder (should be next to the brake Master) down to the transmisson, it will lead you to the slave. It should look like a roll fo quarters with a plunger sticking out that attatches to a lever that goes inside the bell housing.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Feb 08, 2009
SOURCE: I need to know the height of a Kia Rio 1500cc 16v cylinder head
go to kiatech .com
Anonymous
  • 3489 Answers
  • Posted on Nov 09, 2009
SOURCE: torque specs for 2004 kia rio cylinder head
youre going to torque it to 65 ft lbs.. start from the centre out and go diagonally. be sure to replace the head bolts and very lightly oil them before installation.
Anonymous
  • 3489 Answers
  • Posted on May 07, 2010
SOURCE: replace the water pump on a kia rio 2004
A little cramped but fairly easy. Email me at [email protected] and I can send you out the step by step instructions.
Anonymous
  • 10 Answers
  • Posted on May 14, 2010
SOURCE: gear box oil filler plug - kia rio 2004
you have to take off the speedometer cable/wiring harness from the top of the trans and fill it from there....one 10mm bolt...very awkward spot...it might be snug, so just take a flat head screwdriver from underneath to tap it loose...
John d
  • 73 Answers
  • Posted on Nov 22, 2010
SOURCE: NO THIRD OR FORTH GEAR
Rebleed slave cylinder if you had third and fourth strong before. Do they catch when you're sitting with the car off and moving gears into position?
2004 Kia Rio. Why did the clutch fail?
there is no slave cylinder it is a cable,
2answers
2007 Kia rio clutch repair
UNless you have a lot of knowledge available to you ( friends with mechanical knowledge ) this is a job best left to a shop to be done. The time to to replace should be less than 4 hours labour plus cost of clutch kit including throw out bearing
My 2004 Kia Rio w/161,000 miles is missing on the #1 and 4 cylinders. I've had the ignition coil, spark plugs, spark plug wires replaced, yet the problem persists. Sometimes, the car runs good for a f
The car computer does the firing of the spark plugs based on info provided to it by various sensors in car. Your mechanic is spot on. Ouch!
NO THIRD OR FORTH GEAR AVABLE ON MY 2006 KIA RIO RECENTLY REPLACED SLAVE CYLINDER
2003 kia rio ,hard to shift into 1st gear
check the fluid in the reservoir for the clutches slave cylinder
If low add fluid and pump the clutch 25 times before starting up the engine. It should shift great after the pumping proceedure. If not the slave cylinder is at fault
2helpful
2answers
I need to find the torque specs for the connecting piston rod? also the sequence and torque for the cylinder head bolts this is for a kia rio 2004 6cyl
22 - 24 ft. lbs. for the rod caps and....
110795143Cylinder Head Tightening Torque and Sequence.
Tighten cylinder head bolts in order shown.
Tightening torque: 36.1 ft. lbs. (49 Nm, 5 kg-m)
Loosen bolts in reverse of order shown.
Retighten cylinder head bolts in order shown.
Tightening torque: 18 ft. lbs. (25 Nm, 2.5 kg-m)
Mark cylinder head bolts for rotational reference.
Rotate cylinder head bolts 90°(1/4 Turn) in order shown.
CAUTION:
  • Do not reuse the old cylinder head bolts.
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
