Check out the Power supply to the lamp . It must not be high . .
Check if the voltages are correct to the lamp's unit and it's PCB
[printed circuit board]. I recommend using a service manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord
is unplugged from the electrical socket.
It is also wise to unplug
any other cables and label them in order to restore them in the right
way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the
outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro
fiber products and not paper.
Please note that in some projectors a
small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding
touching the glass of the lamp itself.
Touching the lamp will deposit
skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the
projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
Please dont forget to vote this answer was helpful
Many thanks
