Hi,The reason for "F 20" is that while there is "NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED." If after 30 seconds not minimum 0.1l of water entered or maximum fill time of 13 minutes is exceeded, the valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. The possible fix for this problem is:If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves. Verify inlet valve operation. If there is water in the unit: Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch. 1. Unplug washer or disconnect power. 2. Verify there is not a siphon problem. 3. Verify wire harness connections to inlet valves, pressure switch, flow meter, and Central Control Unit (CCU). 4. Check all hoses for possible leaks. 5. Plug in washer or reconnect power. 6. Verify pressure switch operation. 7. Verify flow meter operation by blowing air through the part and measuring the resistance. 8. Verify CCU operation by running a Diagnostic test or any cycle.
Whirlpool Duet front-load washer F02 usually means it is taking over 8
minutes for the washer to sense that the rinse or wash water has
drained, which either means that the drain/filter is clogged or the
pressure switch/tube is clogged (causing both the washer to over-fill
with water and not sensing that water has drained).
To clear out
the drain/filter, tilt the washer backwards a little for easier to the
kick-plate and support the front bottom with a wood block or similar,
remove the front kick-plate's (3) retaining screws and swing the
kick-plate up out of the way. The filter drain is behind the white knob
in the center, be prepared with something to catch any remaining water
and lots of towels to soak up any spills, and turn the knob
counter-clockwise to remove the filter.
The F20 code for insufficient water going into the machine.Checked the hoses and water valves at the wall to make sure high pressure water is going to the washer. You can try a different Cycle water temp setting.Like Cold/Cold or Hot/Hot to see which valve is not letting in the water.
There has been some know failures of the cold water inlet valves. That Whirlpool part number 8540751. I hope this information has been helpful. Good Luck.
inside the machine should be repairmans instructions. this includes explanations for all the error codes. you will have to remove the front access panel
“F20” on display (Water Inlet Problem—no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
