Question about Dewalt 7.2-18.0 Volt One Hour Charger
Light blinks and battery doesnt charge - Dewalt 7.2-18.0 Volt One Hour Charger
    New Friend:
  • 94 Answers
Battery is probably dead. it has been my exp.
Posted on Apr 21, 2010
6ya staff
SOURCE:
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Red light by the battery is blinking n doesnt turn on
Hi bklynzrealis,
Seems that you battery needs charging, if you already did recharge the battery then the battery needs replacing if the red light blinks after charging.
I hope this help.
have a nice day,
mvincnetc
Jul 12, 2011 | Sony Cyber-shot DSC-W200 Digital Camera
Comp went off with the battery lights blinking and doesnt charge
if that is the case, please call compac tech support 1-800-888-0220. This might be a battery problem. They can replace the battery for sure...
May 15, 2010 | HP Compaq nx6110 Notebook
Sounds like your wall supply is gone bad, you must check to see, remove battery, an use only wall supply, if it doesn't go, it is that. if it does, then your battery has gone faulty.
Mar 30, 2010 | HP Compaq nx6110 Notebook
With a full charge chair stops working and won"t power up
I have a Jiffy Jet3 . the problem is when I charge the batteries
the light indicator just blinks but chair doesnt run.
I just put new batteries and still doesnt run,,,thanks J.J.F.
Feb 12, 2010 | Jet 3 Ultra Power Chair
97 Legacy Left key on. battery dead. charge battery and all four turn signal light blink, 4 ways not on. lights blink for while then stop. Engine will not even turn.
try disconnecting battery termainals for five seconds and try again if thats doesnt work check all fuse in car and under hood.
Oct 15, 2009 | 1997 Subaru Legacy
Doesnt stat up and no light showing charge
Here's one way to determine the problem.
Take the battery out and try to boot on AC power only, if it boots turn it back off, reinsert the battery again and try to boot.
Sometimes you just have to take the battery out and plug it back in again, with others it is the battery and you have to leave then out until a replacement is bought.
If it still won't boot on AC only, remove and reinsert the memory, try to boot the computer and listen for any beeps.
Post back if you need further assistance.
Good luck.
Aug 03, 2009 | Gateway MT6840 Notebook
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 | Cameras
Dewalt 7.2-18.0 Volt One Hour Charger Logo
678 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
