I just installed a Canon DFX-5000 printer on my Acer Aspire One laptop, but it will not print. I had to manually choose the drivers, but they were listed. I tried following the troubleshooter, but nothing worked. I can't even print from notepad or a command prompt. Help
The manual is available as a PDF at the link I have provided below.
http://support.acer.com/acerpanam/manuals/acer/0000/userguides/Aspire%208920%20series%2020080205.pdf
You can hook up Acer Aspire to your Epson Printer Using the USB Port if the printer supports the USB port A type. I am not sure what model of Epson printer you are using. You may have to configure the printer either by going into add remove hardware and scanning for hardware changes and installing the Printer, or may have to put the Driver CD provided to you by the driver manufacturing company and install the driver which will also allow you to print a test page at the end of installation to give you a clear picture that the installation was successfull. Please ensure that the printer is connected to the laptop and is powered on while giving for a test print. Good Luck.
If You downloaded the correct wifi drivers and still didn't get wireless...
Choose a different series... Try acer aspire 3000 wifidrivers... then Acer Aspire 5000 wifi drivers, if still no luck... Choose the acer ferrari 3000 wifi driver.. or the acer travelmate 5530 wifi driver/..
I've had alot of Acer Aspire models.. including yours... and I too would have to jump around to different models to get all correct drivers,...
you need the printer driver for vista in order to be able to print out. But Canon does not offer drivers for XP and Vista for bjc-80, however you can manually install the driver for BJC-85 and get the printing function going, but the scanner cartrige does not work through USB.
Hi there, You need to download and install the audio drivers for the laptop. Go here to Acer support, choose your operating system (Vista, XP) and download the audio driver >>>>
check in device manager, is your wireless card detected in device manager ?
if not, it's look like your wireless card is defective.
if yes but there is question mark, you need to re-install wireless driver.
if yes, and it isnot detect any network, is wireless card in your device manager enable ? if disable, right click on wirelees card and choose enable.
if step above not working, try to enable using wireless switch .
at first you disconect your printer cable. and reset your laptop then conect printer cable and anstall driver auto.setup printer driver and chack test print.
