HP Officejet Pro L7580 All-In-One InkJet Printer Logo
Posted on Mar 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
Sir,
Recently we purchase the HP Officejet Pro L7580 All-in-One in which threre is provision of three coloured ink cartridges and one Black Ink Cartridge. Our Blank Ink Cartridge emptied and we have ordered for new one to our dealer. When we enquired from him whether we can proceed in the absence of Blank Ink filled in the cartridge (as per display on the Printer), he expressed his inability to confirm. We think there should be a solution. I have changed the setting in Printer's Properties in the Colour management as 'Manual' (instead of Automatically) and set RGB as default, but can't get the prints. Can you help me and confirm?
Regards
S. D. Parashar
International Control & Projects
[email protected]
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 210 Answers
  • Posted on Mar 19, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
210
Questions
Helped
93163
Points
569
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
1helpful
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Hello, I have an HP Officejet Pro L7580 All In One printer. Sat for 2 years. Barely used when purchased 3 yrs ago. Just hooked it up again. Replaced all ink cartridges...now prints are very pixelated and...
Try doing running it through it's aligment process.
It is also possible that the contacts where the ink cartridges mate up with the printer are corroded. Try using an eraser to clean the corrosion off the mating surface in the printer.
The black ink print is very very faint
Indicates that the printer is using only color ink to create a black color. Check printer settings to see if you can set it to use only black cartridge. Also try printing with only the black cartridge inside if the printer permits, this way you can be sure if the black print head is faulty.
Hp l7580
Hi, it sounds like a faulty ink cartridge. Try changing the black cartridge and see if this helps
Black Ink won't print
Try cleaning the printheads:
On the control panel press Setup>Select Tools>Select Clean Printhead
If that doesn't work, try manual cleaning the printhead contacts. This begins on page 147 of the User Guide.
L7580 User Guide
1helpful
2answers
Empty ink error message
Hi, its sad to say but the printer sounds that needed to be send to the nearest service center in your area. You already reseat & replace the ink cartridge and issue still present. Please call your printer manufacturer so that they can give you more options aside from sending it to service center. Thank you so much,
Tirzo
2answers
Printer claims black ink cartridge is empty, but it can't be.
Se if the tape, that comes with a new cartriage is of the cartriage if not try a new cartriage if the does not work your machine needs service
k24674
Grand Canyon Tech
Grand Canyon Tech
