Model AR-M257 - I have several Sharp MFP devices at different locations and
all are set up to scan through our email server using a special account I have
just for this purpose. I have all of
them setup using the external IP address of our Exchange server (not its name
or FQDN) and I have firewall rules setup to allow SMTP from the WAN IP
addresses of our different offices to the LAN IP address of the Exchange server. It worked at all the others but this
one. I was getting the following error
when trying to send a status message (under Log) from the device to my email
account as a test: [error 973] incorrect
format for primary smtp server. And when
I tried to scan through our email server I would get "network error". However, a connection test succeeded. I had everything set correctly for SMTP and
DNS but as I was trying anything I could to get it working I went to mDNS under
Services and it was enabled. I disabled
it and then I could get a status message to be sent to me and we could send a
scan through our email server.
SOURCE: How can I get a meter reading from an AR-M237?
press and hold the the button that says "copy" on it next to the screen, the meter should show on the screen
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
SOURCE: IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP. That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier. If you can get a control panel screen of the copier to appear. It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
SOURCE: I need to change the IP for my ar-m237
Try to increase the router range to include the ar-m237 or change the copier to a lower IP address within the range of the router.
SOURCE: Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. [email protected]
