Hi
Thanks
for using FixYa. A plasma TV is a very hard working device. It is
working harder than any TV that has been built before, and as a result it
produces a lot of heat. 75% of technical problems in plasma TV's are caused by
overheating problems. You’ll need to check the power supply board first for any
swollen/bulged capacitors. As power supply board is the hardest working board
in a plasma TV, it develops voltage to supply all components, high current +
high voltage. All this is only recommended if you have electrical expertise
& know how to solder/re-solder components as these units contain high
voltages even when switched off. Please do accept the solution if the issue is resolved or
else revert for further assistance.
Thanks
Rylee
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
The tv is mounted on the wall. Do I need to take the tv down to get to the power supply board?
Sandi
I'll accept this solution for now. After I have an electrician check it out with this information, then I'll know if this is the solution.
Thanks
Sandi
