check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Chest freezers produce cold very slowly, so it could be an hour or more before you start to feel the cold. If still no cold, ( and I mean absolutley no cold) then you most likely have adamaged refrigerant line and the (freon) refrigerant has been lost. Take it back, or call for warranty repair.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Marc is correct, you should check to see if you have a blocked filter (this should always be changed when a system is vacuumed and refilled) or you may have oil in the line(s) causing the blockage. But you should know that there is a blockage because your low side pressure will be lower than it should be or in a vacuum and your high side pressure will be much higher than it should be. The blockage could be oil, or a plugged filter or even moisture in the system which will freeze at the end of the capilliary tube in the evaporator which blocks the flow of the refrigerant. But if this was the case the freezer would start to cool down but only for a short time from first start-up then warm up as the capilliary tube plugs up with the frozen moisture. I would suggest that you remove the refrigerant, purge the system to be sure there's no oil etc int he lines, remove the old filter and install a new one, put the system into a deep vacuum for several hours, refill the sytem with the correct amount of refrigerant and monitor it to see if there's a change. Good luck
