MAKE SURE YOU HAVE THE DIALS ON THE CORRECT SETTING. IF SO, TAKE A LOOK UP TOP AND PUSH AND HOLD THE DOOR CLOSE BUTTON, WITH DOOR OPEN UNTIL YOU HEAR THE FAN COME ON. IF THE FAN DOES'NT COME ON WITHIN 5 TO 10 MINUTES, THEN YOUR FAN IS NOT BLOWING THE AIR DOWN. TAKE APART THE INSIDE OF THE TOP BY REMOVING BOTTOM AND BACK PANELS AND AIR FLOW DUCT WHICH ALLOWS THE AIR TO FLOW DOWN. SOME MODELS COME WITH ICE MAKERS, REMOVE THIS 1ST. 2ND THE BOTTOM. 3RD THE AIR FLOW DUCT. 4TH THE BACK PANEL. NOW WITH YOUR FINGER, SPIN THE FAN BLADE TO SEE IF IT TURNS FREELY. IF IT DOES, PUSH IN AND HOLD THE DOOR BUTTON IN WITH THE DOOR OPEN UNTIL THE FAN STARTS TO SPIN. NOW AT THE BACK OF THE TOP IS A DRAIN HOLE AND AIR CANALS. MAKE SURE THEY ARE NOT FROZEN SHUT WITH ICE. IF THE DRAIN HOLE AND AIR CANALS ARE FROZEN YOU CAN USE HOT WATER TO DISSOLVE THE ICE, BE SURE TO PUT A BUCKET AT THE BACK OF THE LOWER HALF OF THE FRIDGE TO CATCH THE WATER AS IT THAWS. WHEN THE DRAIN HOLE IN THE BACK IS COMPLETELY CLEAR, YOU WILL HEAR A SLURP SOUND. DO NOT POKE OR TRY TO CHIP ANY OF THE ICE LOOSE BECAUSE THIS WILL DAMAGE THE UNIT AND YOU WILL LOSE ALL COOLANT. AFTER YOU HEAR THE SLURP, IT'S CLEAR. MAKE SURE NO ICE IS BETWEEN THE AIR CANALS AND BEGIN TO PUT THE TOP TOGETHER. 1ST HOLD THE DOOR BUTTON UNTIL THE FAN RUNS THEN RELEASE. 2ND MAKE SURE THERE IS NO MORE ICE BLOCKAGE. 3RD PUT ON BACK PANEL MAKING SURE IT DOES NOT TOUCH THE FAN BLADES, AFTER PUTTING ON THE BACK PANEL, SPIN THE FAN BLADES TO MAKE SURE IT SPINS. 4TH PUT ICE MAKER BACK IN IF YOU TOOK ONE OUT AND MAKE SURE YOU CONNECT THE CONNECTORS FOR IT. 5TH INSTALL THE AIR DUCT. 6TH INSTALL BOTTOM PANEL. YOUR DONE. NOW CHECK FAN FOR PROPER OPERATION IN THE MANNER STATED EARLIER, AND IF IT OPERATES WITH NO PROBLEMS THEN YOU HAVE REPAIRED THE PROBLEM. IF THE FAN DOES NOT WORK PROPERLY, THEN REPLACE THE FAN MOTOR. ALSO REMEMBER WHEN YOU RESET YOUR COLD DIALS INSIDE THE FRIDGE, IT TAKES AT LEAST 24 HRS. TO ADJUST ITSELF. THIS TAKES APPROXIMATELY 45 TO 1&1/2 HRS.
The noise is water dropping on the hot defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
