The washer's hot water continues to run even when the machine is off, I had to turn the water valve off to the washer. The Cold cycle works fine and even when I put it to Cold wash and turn the hot valve on it starts to fill immediately. It doesn't seem to be a water level problem because the washer works fine as long as the hot water is turned off to the machine I have a Whirlpool Estate washer that runs fine when I only use cold water. If I turn my hot water valve on, the washer fills continuously with hot water even when the washing machine is implugged.
My washer does'nt evaluate the local load size and continue to fill and there is no wash motion
Our hot water tank broke and I can't get a plumber till Monday. I tried to run a load on col/cold but it stopped about 10 minutes into the cycle and gave me the H F error code. Can I run it without the hot water turned on??
The water supply to the washer is fine. Filter screens are not stopped up. Supply lines are new. Hot water runs in just fine but the cold will bvarely run in. Takes for ever to fill with just the cold.
