Question about Kodak EasyShare M863 Digital Camera
Battery dosn´t charge, camera gets hot
My kodak M863 is only 1 year old. Now the battery (Li-ion KLIC 7001) dos not charge and the camera gets very hot when it is connected to the charger. Can you tell my what is the most probable malfunction (battery, camera or charger)?
Regards
Silvério Machado
(e_mail: smmmachado@gmail.com)
5 Suggested Answers
Anonymous
SOURCE:
leepania
Pania Lee
  • 1099 Answers
SOURCE: Kodak EasyShare M763
KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 13, 2009
1alexh
Alex Howard
  • 484 Answers
SOURCE: Camera won't turn on using recommended KLIC-8000 battery
It is possible they sold you a faulty battery pack. .
Contact them and explain your problem; they should replace it at no cost to you
-a.
Posted on Jun 05, 2010
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: my problem is that i
http://www.amazon.com/Kodak-KLIC-7001-Compatible-Battery-EasyShare/dp/B000JEWW80
I think this will do ..cause if ti was a adapter capable of running the camera while charging ..I didn't found any ..cause it is a rare Japanese model ..
Posted on Jan 24, 2011
caroldon
  • 17130 Answers
SOURCE: kodak V610 will not turn on. I have bought a new
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it out slowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt.
Tips to open and check for common faults: http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related
Use some air to blow between the lenses to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must you try and open. If so check the voltage on the motor drive check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Posted on Oct 26, 2011
What battery number fits in my kodak easyshare m1063 i bought a KLIC-7001 AND IT DOES NOT FIT.
Hello, Elsie -
The user manual for the Kodak EasyShare M1063 camera states it takes a Kodak Li-Ion rechargeable digital camera battery, KLIC 7001.
See the user manual (PDF document) here:
http://resources.kodak.com/support/pdf/en/manuals/urg00868/M1063_MD1063_MX1063_UG_GLB_en.pdf
Page 1, Step 2 even has an illustration of the battery and the direction in which to install it.
If the battery still does not fit, I suggest you visit a nearby store which sells cameras and camera equipment and ask one of the individuals working there for assistance with the battery and camera. (Take the camera and battery with you.)
Best wishes.
Feb 21, 2018 | Kodak Cameras
What type of battery charger does it need
These battery types are compatible with your camera...
Rechargeable Batteries:
* Li-ion Battery Special Size Lithium Batteries: Uses 1 Li-Ion (3.7V, 720 mAh) KLIC-7001
Visit KODAK Store for a complete list.
Hope this helps (remember to rate thsi asnwer).
Dec 15, 2010 | Kodak EasyShare MD853 Digital Camera
-a.
May 13, 2010 | Kodak EasyShare Z712 Digital Camera
After taking 2 pictures with my camera, it shut off
Yeah your correct there might be a problem also in the battery., are you using the battery came form the box of your camera? or using the recommnded battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001 If yes you may call kodak toll free 1 800 235 6325, It means that your camera needs of service
Nov 01, 2009 | Kodak EASYSHARE M1063 Digital Camera
I press the on button, the lens doesnt extend and the power shuts off
are you using the recommneded battery fro your camera KODAK Li-Ion Digital Camera Battery KLIC 7001? If yes please charged the battery for 3hrs and try to turn on the camera., if encounter same problem it means the gear lens of your V550 is already defective and needs of repair please call precision and binocular repair at 1 800 665 6515.,
Oct 31, 2009 | Kodak EasyShare V550 Digital Camera
Camera will not turn on
are you using the recommended battery KODAK Li-Ion Rechargeable Digital Camera Battery KLIC-7001? if yes did you charged your battery? If yes try to check if the camera has blinking light on it while its charging? if doesnt have the light there might be a problem on the camera or may be the charger.
Now if has the light indicator thats a good sign., please clean the 3 metals contacts of KLIC-7001 then turn on the camera again., if this solutions did not solved the issue it means camera needs of service please kodak kodak Toll free 1 800 235 6325 for U.S and Canada support only
Oct 26, 2009 | Kodak Easyshare M753 Digital Camera
I went ahead and looked this up for you. Kodak says you need a Li-Ion Rechargeable Digital Camera Battery KLIC-7001.
You had the right idea, but the wrong number. Hope this helps.
Aug 17, 2009 | Kodak EASYSHARE M763 Digital Camera
Batteries are kodak li klic 7001 cameras areeasy
The batteries may just be "dead" and beyond charging. Before you toss them though, clean the contacts by wiping them firmly with a soft cloth and then try charging them again. If the problem persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Kodak EasyShare M863 Digital Camera Logo
162 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
