When using the kindle 1 it is all blurred at the top, like smeared ink about one inch. Originally it would not show anything at all when turned on but I took out the batter on the back and plugged it back in, pushed the reset button on the back and now at least text shows up but it is, as I stated, blurred or smeared at the top of the text. Any ideas. PS. I contacted Amazon Kindle and they said I could get a refurbished one for $100 and send this one back. I would rather try to get it to work.
Amazon.com, Inc.Same here. I plugged it in and it shows a green charged light but still will not turn on. Anyone else? 75 people think this reply helps answer the question. Do you ...
Oct 29, 2010 - Answer from millioneir2be. 6 people found this helpful. OMG- I went into a kindle frenzy when it would not turn on. BUT thanks to the support of ...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
I'm afraid this usually means your screen is cracked. You can contact amazon customer support and they may replace it or you will have to but a new kindle
Are you sure the Kindle powers up? It may show something on the
sreen, even if it is not turned on (e-ink screen does not need a
powersupply to show an image). Try to power up your Kindle with a
different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Well there are a lot of reasons why the Kindle screen freeze.
most of the times it happens when the Kindle is trying to upload some big files like photos, movies, flash etc. in this case all you have to do it to wait and it will un-freeze in couple of seconds.
Another Very common is that the Kindle Memory is full and he can't respond until some of the memory gets free, this usually will happen once you click too many times on the screen, the poor Kindle is overwhelmed with orders and doesn't know what to do, this happens to "newbies" with the kindle.
A lot of these freezing problems can be fixed by resting your Kindle, you can do a Soft reset press the Alt-Shift-R keys at the same time. (Shift is the one that
looks like an up arrow.) If that doesn't work, plug your Kindle into
the charger and try again.
You can also do a Hard Reset take the cover off the back and insert a paperclip in the little hole. Hold for 10 seconds, you may need to try again with the Kindle plugged into the cradle.
For the Kindle DX Hold the top on/off switch sliding it to the left and keep to the left, hold for 60-80 Sec, Release it. Wait a minute - the DX will flash. Then the screen will go black and then the
main Kindle screen (the guy sitting under the tree) will appear and the
start up thermometer bar. Once that's completed, the main menu will
come on, and your books will be rstored in batches over the next couple of minutes
And of course you can always CallAmazon Customer Service at 1-866-321-8851, 6a-10p PST, 7 days a week
