I have recently replaced my fusing unit. Upon powerup with the new unit I tried to run the fuser adjustment procedure. It started and after a few moments failed. I entered the Maintanence menu and tried to run the fuser adjustment and I got the message "Cannot Adjust, See Manuel". After looking at the manuel it said I had to make sure I had plenty of toner, so I put in all new toner cartriges. Still no luck getting the fuser to adjust and even my IKON guy was confused. Got any suggestions.
Hi there set the transfer belt into the home position then power on this resets the transfer home which then allows calibration. Tray this if not replace transfer unit.
Thanks J
J, I may have a problem with the HP sensor. Would the printer continue to work if I had a defective, dirt, or blown fuse on the HP sensor?
