Question about Hitachi 42PMA400 42 in. Plasma Television
Intermittent noise coming from back of screen
Sounds like a fan hitting something but it stops when the image on the screen is dark. It has always had a slight buzz on white images but this is much louder.
  • Hitachi Master
  • 8,457 Answers
No,fan in Plama tvs,fan only in DLP tvs.One of the power transformer in the power supply board is not give out the right high voltages.
Posted on Apr 14, 2010
  • hixtar Mar 19, 2011
    Where can I get a spare power board or is it serviceable ? I had the same problem with mine but then it just gave up the ghost and I got no Red or Green Power light, totally dead. Hitachi agent here said they can't get the power supply as it is a UK model.
6ya staff
SOURCE:
Laptop recently started to make noise on start up, feels and sounds like it's coming from the area below the keyboard in the lower left part, it's an acer aspire 5570-2067. it makes noise for a while, then...
Def sounds like the fan , from where you say the sound is coming from . normally the fan should be able to be cleaned the panned holding the fan in the left hand corner . clean the fan with compressed air , or a paint brush . if this fails then you need a new fan .
Nov 23, 2010 | Acer Aspire One PC Notebook
GBS20HBSBWW BOTTOM FREEZER, MAKING LOUD NOISE WHEN I TURN THE ADJUST KNOB IN THE REFRIGERATOR TOP TO 0 THE NOISE STOPS.
It sounds like your fan is hitting something. Usually there will be an ice block or something in the freezer pushed in on the back and cased the fan or wire to move ect... I hope this helps
Aug 11, 2010 | GE GBS18HBR Bottom Freezer Refrigerator
Hot Point rattle noise after it runs sounds like noise is coming from the back near the top . refrigator model # CTX21GAXSRWW
Hi the sound come from the fan it is locate inside the freezer behind the back wall.
you can open the back wall and check if the fan hit something.. some times it hit ice ..
let me know if you need more help.
Jan 12, 2010 | Refrigerators
When my MIM2330 is switched on, some lights flash, and intermittent whirring noise, which stops after a few minutes, but screen completely black. Suggestions please!
could be your hard drive thats dead. You might want to go buy a new one. Depending on if you have a warranty on it you should pop open the case and try turning it on if its coming from the hard drive your hard drive died. It also could be a fan hitting something slowing the cooling process and overheat your processor.
Oct 26, 2009 | E-Machines (T2824) PC Desktop
Funny noise when TV is on
if the tv is a "DLP" the "color wheel" is going bad, check the model # to get the right part
Nov 28, 2008 | RCA Scenium D40W20 40" Rear Projection...
I have model # RS2630WW Samsung regrigerator making a lot of noise that seems to be coming from the back panel area. When I remove the 8 screws, it's seems to be coming from the fan. (I disconnected the...
fan can not be lubricated and they can get noisy.
however, a common reason is the fan blades hitting ice that has built up. check for this
Sep 06, 2008 | Refrigerators
I have a Sunsung RS21JLSG, and it's not chilling the food like it should. It's making terrible noise, sounds like a generator. Anyone know the problem?
Fan blade is hitting something probably, could be ice buildup in the freezer compartment. Open the freezer door and see if thats where your noise is coming from. If it is coming from the back of the refrigerator at the bottom could be something was drawn into the fan causing you noise.
May 05, 2008 | Refrigerators
LG Fridge making intermittent sound - like something hitting fan
GAIN ACCESS TO THE FAN IN THE FREEZER(EASIER SAID THAN DONE) AND INSPECT THE FAN BLADE AND FAN SHROUD. HAVE REFRIGERATOR TURNED OFF AND MANUALLY ADVANCE FAN BLADE. WATCH FOR SLIGHT CONTACT BETWEEN THE FAN BLADE AND OTHER OBJECTS NEAR IT-ELECTRICAL WIRING, FAN SHROUD, ICE CYCLE,ETC. ADJUST FAN BLADE OR OBJECT TO INCREASE CLEARANCE.
Mar 27, 2008 | Refrigerators
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Hitachi 42PMA400 42 in. Plasma Television Logo
99 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
