Couple years old Frididaire stove is operating hoter than the temp set on the dial . what could be he problem with the temp sensor or what
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
is te oven hotter than it should be, or ist it a top element your have a problem with, and if the oven, how did you notice this exactly????
