SOURCE: My 120 GB I pod classic Doesn't play the next song
Hi.
Check that when you plug your iPod in that it isn't selected to "Shuffle," play which can happen if you are expecting to go through songs. There is also another reason and one I didnt know about until I took my iPod Classic back to my retailer thinking there was a problem;
If the songs on your iTunes or default device isn't an AAC file the iPod will fail to play it. On MAC systems simply click the file that you want to put onto your iPod, right click and scroll to "Get Info." If the file doesn't say it is an AAC file it won't play on your iPod. Scroll further down on the list to "Create AAC version." This takes milliseconds, doesn't affect the sound quality but condenses the data fit for the iPod Classic. Once that's done you can add any song you like.
Generally when you put a CD into a MAC it will automatically change the AIFF files into AAC which means you don't need to manually convert. AAC is usually needed when individual tracks are called up and put onto your iPod. I hope this helps you - it drove me nuts until I found out about the AAC.
SOURCE: only plays first few seconds of a song
if you are using ROCBOX go to settings./ play back settings..enable party mode/replaygain/crossfade...its playing like all intros......if this is straight iriver firmware you can try settings and look in playback setting also
SOURCE: My Ipod classic 80G has stopped playing music.
Make sure that you got all of your songs off of itunes, or that they have been converted through itunes correctly. This is caused by songs being the wrong format, or that the song itself is corrupted. Try restoring the unit through itunes, and loading the songs back on. If you are running with your unit while trying to listen music this can also cause the unit to freeze up when playing a song. Any type of continuous motion can cause your ipod to not play songs. This is because the ipod has a hard drive inside of it, and when you move alot with a hard drive it cant read correctly. If you want to run with your unit, i would suggest getting a flash drive based mp3 player (ie itouch). If you have any further questions feel free to contact www.wiredextreme.com.
