Re: roaming profile error when I log on with my...
How to solve Windows cannot find the local profile and is logging you on with a temporary profile. Changes you make to this profile will be lost when you log off.
Windows has a roaming profiles if you are on a networked computer. Change it back to local if you have rights and not on a work PC. Right click My Computer > Properties > Advanced > User Profiles > Settings. Highlight the profile and Change Type.
It looks your profile is corrupted. You can login with administrator's login id other than the local profile user id and rename the old profile located in c:\documents and settings\ your user login name folder
and rename the folder. After that logout and login again with your user id, one having problem with profile and again go to the c:\documents and settings\ your user id name folder which you renamed and move your critical data on desktop or my documents to the new profile.
had similar problem w same router when originally purchaased call linksys theyll walk you through it there custmer support is xcellent and they speak english only takes a few minutes
Sounds like you took your work computer home to do some work and its looking to connect to the company server to get your credentials to give you access to the system and files.
I would guess you need the VPN connection to connect to the server its looking for.
From what info you provided that's all we can tell you.
When you "logon" to your local network, your computer is configured to fetch your "desktop" (My Documents and wallpaper and everything else) from a "server" computer on your network.
Was your "logon" to the local "domain-server" a successful login?
Does your local Network Administrator indicate that the "domain-server" is functioning properly?
Does that server's log-file show any error-messages, such as "not allowed to login between 10 PM and 6 AM" (a "security" setting on the server).
Since your "desktop" could not be loaded from the domain-server,
your computer has used a "local" copy of your "desktop",
and it is warning you that any changes will *NOT* be "merged" back to your "network" profile.
Have you contacted you local Network Administrator? What did she say?
Your windows profile is broken,.or loaded from another computer (or server) that is down or not running. If you and your computer go direct to the net, not through some kind of network, then you might want to creat a new ADMINISTRATOR profile (via windows control panel)and delte the old one once you have copied what you need.
