I bought the europe map and now nothing works i cant upgrade it .everly time I try it crashes.
Connect the GPS to the computer. Forget the Tom Tom home for a little while. Use the windows explorer or file manager. Check whether the TomTom is shown as a drive. If yes, Right click on it. Then click properties. Check how much is the used space and how much is the free space. If you see that there is only about 50MB free space, that could be the reason. Tomtom update do not seem to overwrite the map file. Now check the properties of the new map file. It may be approximately around 1.3 GB to 1.5 GB. Since I do not have a Europe map I do not have the correct size. If the new map size is anything bigger than the available space on your GPS drive, then the update will not complete and crash. Solution. Copy the existing map (North American map has a name something like USA_Canada_and_Mexico_P) folder to your computer. Once you have a secure copy, delete this map folder from your GPS drive. You will now see that you have approximately 1.7GB of free space. copy the map folder from your CD to your GPS drive. Once copying is complete, safely remove the GPS from USB port. Restart and try it out on a known route to check efficiency.
