Life Fitness 9100 Next Generation Remanufactured Treadmill Logo
Posted on Apr 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY TRIMLINE brand treadmill has power but the belt does not move even though the screen shows that speed is on. what do i do? also i need a reliable and reasonably priced repair service center. Pls recommend. thanks you.
John Mazmanian
Level 3:
President:
  • Life Fitness Master 832 Answers
  • Posted on Apr 16, 2010
John Mazmanian
Life Fitness Master
Level 3:
President:
Answers
832
Questions
0
Helped
628540
Points
2056
TrimLine was part of Nautilus until they were phased out Your problem sounds like the lower board is causing the problem. Not knowing where you are located it would be hard to direct you to a servicer near you , but ultimately you will need to call and see if you are comfortable in the way they handle you over the phone. If you are game to repair this the only tool you will need is a phillips screw driver. Unplug the unit pull off motor shroud and you will see a lower electronics board get a pencil and pad make a drawing of board ( stick man drawing good enough) and make notation of where all the connection go to check it twice before disconnecting and usually their are only 4 screws holding the board. Now you may purchase this board Treadmill Doctors.com just them M# and Ser# and they should be able to help you. Good Luck!!
  • 1 more comment
  • Anonymous Dec 24, 2011
    Sounds like the same problem I have. Trouble appeared after I'd moved the treadmill. Local tech, tested the motor by touching red and black wires to the posts on a rechargeable drill and motor and belt moved fine...but no power coming off the board posts to the motor, even though everything else seems to be working...just no belt movement. He diagnosed a lower board issue. Trimline is no longer made but it was a $2000+ treadmill so may be worth saving. He pointed me to Fitnessrepairparts. com as the sole source of old, and rebuilt parts. I ordered a new board, which is really easy to install btw, but the treadmill acted exactly the same way. All lights, menus, clicks, sounds, etc seem to work, but belt wont move. Tried the drill battery test again and the belt moves fine. Just not sure what to think, but the replacement board was $350...and didn't help me a bit. Still working on it.
  • Anonymous Jan 30, 2013
    did you ever figure this out...I also bought the replacement board and didn't help. I would love to know how to fix this.
  • Anonymous Feb 22, 2013
    commenting on the above it seems i a faced with the same problem when we moved the treadmill it seems that there is no belt movement at all does sometimes come up with an e1 error .. would like to get to the bottom of this and get it fixed once and for all .. post back please
How do I calibrate a Trimline 4650.1 treadmill?
WARNING: DURING THE ENTIRE CALIBRATION PROCESS, STAND ON THE PLASTIC SIDE RAILS ONLY!
DO NOT STAND ON TREADMILL WALKING BELT!
CALIBRATION
1. Turn off treadmill.
2. Simultaneously press PROGRAM, ENTER, and START/STOP for about 3 seconds.
3. Maximum speed will be shown in the TIME/PACE display followed by an "E" for English units or an "N" for metric
units. Press START/STOP to change from English units to metric units.
4. Press ENTER.
5. Press START/STOP. Incline and speed will calibrate simultaneously.
6. When successfully completed, TIME/PACE display will show CAL PASS.
7. Press POWER. Your treadmill is ready for use
My trimline 2200 treadmill will not start the belt. I started having problems where it only worked on very slow speed now the belt won't turn at all. I tried pushing the circuit breaker reset
Likely your motor wore out, or that the circuit for the motor driver is shot. If the panel is starting it is likely that the motor is not getting any power at all.
Trimline t340 treadmill
However try to LUBE with WD-40 first, if do not work go to
Treadmill Treadmills Best Treadmill Treadmill Doctor
Blessing
[email protected]
cell+whatsAPP:+50588611441
Trimline treadmill repair e1
Your motor controller needs to be replaced. You’ll also want to replace your walking belt.
Treadmill giving me error P1U
Got it. See last page of manual found here: http://webpages.charter.net/chestnuts/Trimline%20Owner%27s%20Manual-1600-2600-3600-4600.pdf
i.e. stuck in calibration mode.
1. Press & Hold PROGRAM INTERVAL, SPEED DOWN and POWER
2. Release SPEED DOWN only (must hear a beep or repeat 1 &2)
3. Release the other two
4. Press PROGRAM INTERVAL (treadmill will move up or down)
5. Press PROGRAM INTERVAL (treadmill will move up or down)
Calibration is complete. Enjoy your exercise!
Eric
Ottawa, ON
The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
Sorry.
Hope this was at least helpfull, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
3helpful
2answers
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
30helpful
2answers
Horizon treadmill won't start running
The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
My Trimline treadmill 1050.E2 is showing an 'E2' on its screen and not working any more.
Hello all,
I have the same issue - it Shows "E2" on the time Display...
I already checked the Speed sensor and inclination potentiometer and both are OK... Moreover, I found that EEPROM Memory (Microchip 93LC46) is broken (reads "00"). After replacing it, I Need a way to reset / recalibrate the treadmill. I found on some Forums that there shall be a key combination (Speed+ & Start / Stop or similar) but None works for me. Could you please (if available) post the User Manual page describing the calibration entry? Or, maybe, advice a way to calibrate the 1050? Even the EEPROM Content (I guess the it is an issue) will be really helpful. Thank you in advance,
Milos
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
