This model is exclusive to South Africa. This link should work local to you as we are in North America. There is a spares outlet listed and the service manual is in the link.
I have the service manual of LG WD 1041-1042 front load washer, I think it's same to WD1070 you are finding. please send email to me, I'll send the manual to you email: tangcamminh52@gmail .com Tang cam Minh
go to www.lg.com/au then click on product support left hand side of screen then type in wd-1018c in search box under box high lighted in red wd-1018c washing machine comes up. click on it. half way down page down load pdf for manual
it will definitely be the bearings and possibly the spider as well. the spider is attached to the bowl. the spider is made of aluminum and they corrode all the time. open the door to the machine and grab hold of the steel bowl, has it got movement on it. if it has then the spider and bearings are faulty, also the main shaft seal will need replacing.nearly every time i went to an LG 8013f that was noisy it was the bearings and or spider. hope this helps. please reply 4 more help. good luck.
You suspect right. It is a complete strip down job. I have just finished mine. taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers. Download the manual from LG. Good Luck
