Sansui DTV2760 27" TV Logo
Anonymous Posted on Mar 20, 2008
Have Sansui @0" tv/dvd/vcr combo that my son locked the parentals control
My 11 yr old son locked the parental chip on the Sanui tv that we gave for  xmas and forge=ot what the code was as he did by mistake plaving with the controls on the remote, is there any wa to unlock it? It's model #TDC2075A Thanks Dale
Anonymous
Level 3:
Brigadier General:
  • Master 3,614 Answers
  • Posted on Jun 27, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
3614
Questions
24
Helped
1009079
Points
10054
This problem need a technical assistance from any professional to service your unit to reset and by pass the codes..
  • Anonymous Jun 27, 2008
    a problem way back from Mar20 - 08..?
Anonymous
Level 3:
Genius:
  • Master 2,028 Answers
Anonymous
Master
Level 3:
Genius:
Answers
2028
Questions
6
Helped
830266
Points
5064
Check out this linkto a google page, the third down has a password reset link, but I'm having server problem and can't get there to post the link for you.
http://www.google.com/search?hl=en&q=Sansui+DTV2760+password+reset&btnG=Search
Anonymous
Level 3:
Genius:
  • Master 1,036 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1036
Questions
6
Helped
411952
Points
3010
Please check a previous posting Here
Thank you for using Fixya!
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on Mar 20, 2008
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1563163
Points
12312
The owner's manual should have a customer service number. Call that and they will give you the universal unlock code. I'd rather not publish such a thing.
Dan
Anonymous
Level 3:
Genius:
  • Master 3,587 Answers
Anonymous
Master
Level 3:
Genius:
Answers
3587
Questions
29
Helped
1146837
Points
9064
Yes..but you'll need to have a service professional do a firmware reset on this unless you can gain access through the service and support menu..
is this a new form of Child Protection and control?
Anonymous
Level 3:
  • Master 6,487 Answers
Anonymous
Master
Level 3:
Answers
6487
Questions
6
Helped
1556213
Points
18452
This should do the trick:
If you forget your password, simultaneously press and hold VOL - on the front
panel and VOL - on the remote for 3 seconds. Nothing appears on the screen,
Parental Controls simply unlock and you can re-enter a password via Lock
Parental Controls
Hope that helps............
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
3answers
Parental controls
try giving the reset ...........
1helpful
4answers
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
MY CHILD OF 3 YRS OLD ACCIDENTALLY PUT PARENTAL CONTROL ON MY DVD/VHS COMBO IS THERE ANY WAY TO UNLOCK IT
By parental control I don't know if you mean child lock. If that's the case you should be able to turn it off by pressing child lock on the remote control until off shows in the display window.
6helpful
Parental Lock
I called the custoner service number 1-866-387-1902 & the parental lock code is 1369. I had the same problem and this worked for me. Good luck. This parental code is for all disney tv, dvd combos.
2answers
Sansui dvd san4312
DVD players don't need parental locks. When a user places a DVD player in Parental Lock mode, they usually create a 4-digit access code to remove the lock. Without the manual, I can't tell you how to reset to factory settings...what you need is either the access code or to reset it.
If it came direct from the factory with a parental lock already on, try the code "0000". If you need more digits, just use 0 until all of the slots are filled. If 0 does not work, try all 1s or 9s.
6helpful
2answers
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Philips remote code for a sanui
Depends on the type of Sansui device. Here is the info I have:
0632 for tv/vcr
0041 for a TV/DVD combo or DVD/VCR combo or DVD or VCR
many for CD players - 0268, 0072, 0973, 0075
0015 or 0632 for any TV
if these fail, the universal is usually 0711
If this fails, I have the Philips digit grid - reply thru FixYa, not my personal e-mail. Make sure to rate me.
-Tha Mp3 Doctor
DVD parental lock
I have a GE 13TVR62 (with a problem listed here). I've learned that the Parental Lock Settings are changed by using the Remote Control. Usually the actual Settings are changed by pressing the Up or Down or Left or Right Arrows to make the Change; while the Parental Lock is Highlighted on the Menu.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
