Ricoh Aficio 1232C Color Copier Logo
Anonymous Posted on Apr 17, 2010
I have a Windows printer set up for the Ricoh 12332C. Jobs are sent and clear the queue, but do not print. They appear to be accepted by the Ricoh - they show in the job history log, but they do not print and I get an "access restricted" message in the job history log. User ID shows has a question mark in it. The log shows the job name and the user who sent but with 0 pages printed. I've tried different drivers and setup. I currently have it set up for LPR printing with a queue name of PORT1. I've tried lp, ip address, and PASSTHRU. They all seem to give the same results. This has to be simple
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 19, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5554
Points
How i place into the print driver my id.???
  • Anonymous Jun 19, 2013
    how i place into the print driver my id.???
Anonymous
Level 2:
  • Expert 114 Answers
  • Posted on Apr 20, 2010
Anonymous
Expert
Level 2:
Answers
114
Questions
Helped
69037
Points
180
Is the copier set up for user ID to copy or print, if so you have to use your user id when printing. there should be a place in the print driver to enter it each time or to have it automatic
Mohamad Noor Haris Fadzilah Mohd. Zin
Level 1:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Contributor 59 Answers
  • Posted on Apr 18, 2010
Contributor
Level 1:
New Friend:
Teacher:
Answers
59
Questions
Helped
20578
Points
67
Usually the setting of yout network with your copier/printer setting is mismatched so your printer.copier did not understand. What you can do you should check the system setting of your copier/printer and print it out then you should find the driver of your printer/copier in the add printer hardware secrtion in control panel of your computer network . Before you reinstall it , you should uninstall the previous driver so there is no conflict when you reinstall new driver . Try it
How do I clear backed up print jobs?
You can go to your control panel and select printers. On Windows 7 and 8 it is devices and printers and click on the printer you want. This will bring up your printer properties. There you will see an icon that says check what's printing. That brings you to your print queue Clear that out.
3answers
Deleting Printing Queue
you must give clear all in log settings....
2answers
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
1helpful
I finally cleared a paper jam, and now my printer is trying to reprint all the documents I sent to print while there was a jam. I do not want these to print since it will waste a ton of paper and ink. How...
There should be a little print queue icon down by the clock.  Double-click on this to open the print queue program.  From there you can remove jobs from the queue.  NOTE:  It can take a minute or two for jobs to remove themselves.  It's not instant.
Please rate me if you found this helpful.  Thanks.
After a ps print job is sent and printed by the
There is probably nothing wrong with the printer, but it may not be be receiving all the dope it needs. Usually the printer needs a CR/LF signal at the end of the file to print. If it doesn't get that it will assume that it hasn't got all the file and will hang. This may be a setting in the application producing the file, or a setting on the printer itself (i.e needing either a full CR/LF signal or just one of these). Don't like the idea that it doesn't print its own test page though....
1helpful
2answers
How do I cancel a print job sent to the Ricoh Aficio 2018D? It is no longer in my print queue, but printer is still printing all 480 pages
You may have to go to the printer and click on Status or printer jobs and cancel the job from the printer. It appears the printer has the whole job already spooled in memory
10helpful
2answers
Unable to delete doc after being sent to printer
First, I would try canceling the document either at the printer (hit cancel if it has already been sent) or at the computer.
You can do this by going to start -> settings -> printers and faxes
double click on the printer to open it
right click on the offending file and hit delete
It sounds like both of these have been done already. So...next option.
Second option - Restart the print spooler
Go to Start -> Settings -> Control Panel -> Administrative Tools -> Services
Click on the "Print Spooler"
Select Restart
Third option - delete the document from the spooler
Stop the Print Spooler by following the instructions above and clicking "stop"
Delete all files in the c:\windows\system32\spool\printers directory
Restart the print spooler.
CAUTION!!! - This will clear out both the offending job and any other jobs that have been sent to the printer after the offending job. If you have a number of other jobs, you may wish to clear out only the offending job from the printers directory.
Hope this helps - flub
I want to print new page of printing printer keeps churning out prvious printing instrctions i am 78yrs old still learning
What you need to do is clear out the printing "QUEUE".
Clearing the Print Queue in Windows
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
1helpful
2answers
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Can not clear the print que
Follow these steps to resolve the issue. Step one: Delete the print queue Open Print Setup Utility located in the Application/Utilities folder. Double-click your printer in the printer list to open the print queue. Click the Stop Jobs icon. Click to select the document, and then click the Delete icon. Repeat the steps for all the jobs in the print queue. When the print queue is empty, click the Start Jobs icon. A message appears: No Jobs Printing . This indicates that the queue is clear. When you have cleared the queue, retry your print job. If the procedure has not resolved the issue, repeat steps 3 and 4. If the issue still persists, continue to the next step. Step two: Remove the printer from the list Open Print Setup Utility , located in the Application/Utilities folder. Click to select the Photosmart icon. Click the red X to delete the printer from your system. Close all open windows, and restart your computer. Step three: Add the printer to the list Open Print Setup Utility located in the Application/Utilities folder. Click Add . Select the printer that you want to add, and click the Add button. After a few seconds, your printer appears in the printer list, and your printer is ready to print.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
