Question about Sony BRAVIA KDL-46V3000 Television
2006 Sony KDL-V40XBRI
Bought Sony Bravia LCD in March 2006 and this March.........picture has vertical multi color lines on lower off of screen ..
Took to Wolf's Repair (VancouverWA) and they have quoted could be two different curcuit boards but can't tell which one until they replace...1st one will cost $650 and if that doesn't fix the lines the second one will cost $900..........
We thought we bought a quality Sony product...Have not agreed to this work yet.........Charging us $80 just to tell they don't know the problem.
Thanks Sherrie and Dave
serenesherrie@comcast.net
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 34 Answers
Sony bravia lcd troubleshooting
https://www.google.com/search?client=ms-android-att-us&ei=O8blWLC3CIvKjwTi54DIDg&q=sony+bravia+lcd+troubleshooting&oq=somy+bravia+lcd+troubl&gs_l=mobile-gws-serp.1.0.0i22i30k1l5.154.16000.0.16940.47.34.1.3.3.0.1404.11353.0j9j4j5j2j2j3j2.27.0....0...1c.1j4.64.mobile-gws-serp..26.21.7197.3..0j0i7i30k1j35i39k1j0i131k1j0i67k1j0i10k1j0i13k1.Ar_4YkwTSbY
Posted on Apr 06, 2017
5 Suggested Answers
6ya staff
SOURCE:
vinnyq
vinnyq
  • 157 Answers
SOURCE: Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Posted on Oct 05, 2009
Testimonial: "Thanks for the response. The service company Sony recommended told me it was probably the screen, too, and they quoted $1000."
tvtek
Don
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
Will Laxton
  • 25 Answers
SOURCE: Sony Bravia KDL series 52"
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Posted on Jun 28, 2011
fredback99
fredback99
SOURCE: Sony Bravia KDL 46V100 has only black & white picture-no color
I bought Sony Color Bravia TV 60 inch, moved with it Kenya, Africa, when i try to tune the color is not coming. I can only get black and white. Please anybody with idea on how to change it for Africa (Kenya). Model:KDL-52SS100. My e-mail. fredwagah21150@yahoo.com
Posted on Jun 04, 2012
COLORED VERTICAL LINE ON THE ENTIRE SCREEN AND NO PICTURE Sony Bravia KDL-46VL160 46 in. LCD HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 03, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony tv KDL-40S4100 vertical lines on right side
Oct 09, 2015 | Sony Bravia KDL-40S4100 40 in. LCD TV
What board is defective on a sony bravia KDL-XBR6 that has a colored vertical lines on the whole screen? No pictures on screen an its just a colored vertical lines...
T'Con board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 05, 2015 | Sony BRAVIA KDL-52XBR6 LCD TV
Have sony model KdL 40S2000, now has colored thin lines going up and down on the left side. Anyone know the cause.
Line faults & possible causes to LCD screen is given with illustrations.
Jul 29, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-40w4100 vertical line issue
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
Jan 10, 2012 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
My Sony flat screen bravia hdtv 40" when i turn it
Your LCD TV needs repair,abnormal display caused by a faulty LCD Control board. Replace the control Board.
Nov 12, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have coloured vertical lines covering my Sony Bravia LCD tv screen. The TV is only 2 years old. I have sound but a very distorted picture. The cable company has checked and says it's a tv problem. I will...
I also have a 2 yr old Sony KDL32xbr4 that now has multi-colored vertical lines on the screen. I contacted Sony and they say they have "no known issue" of this sort for this model. I find this rather puzzling since I have found numerous postings on the web. They told me to try the factory reset. Whatever. Might as well have said "don't buy a Sony". 2 years! $1300 for a tv and it lasts 2 years! Makes me sick to my stomach.
Jan 02, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Screen has color. but no picture. only moving multi colored vertical lines. tv does have sound, but no picture.
Unscrew the cable off the cable box on the out to TV end, then screw it back on. You may also try a different type of cable, like HDMI or component cable.
Dec 27, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia kdl 32l4000 - color bars running vertically on screen
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA  KDL-46V3000 Television Logo
337 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
