HI....My Fridge only cools down in the bottom part of it.
I have a Frigidaire that stop working properly a few days ago. I have noticed that it cools down in the cold area (right hand side of the fridge) just in the bottom two shelfs. The same is happening in the freezer ( left hand side of the fridge) where the two bottom shelfs freeze the food; but the rest is warm........
I do not hear any noises recently. I would appreciate any tips to start my root cause investigation
Re: HI....My Fridge only cools down in the bottom part of...
Hi, As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Remove the rear lower panel on the unit check to see if the compressor
is hot or if its running, should feel the vibration, also listen for
any clicking noises.
So if your voltage changes with the fan plugged in, it would seem that your fan is blown and you need a replacement. This fan is needed to properly cool the top. You should be able to order the part directly from Frigidaire or there are many online sites to choose from. If you need help with this, let me know or if you have any other questions, just ask, otherwise, good luck
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your
refrigerator and why it is not cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
