Most possibly be Error code 56,
Is common in 11 series machines & early series 12. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code, To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
Your fault code is 112
Info for your fault code. 112. (01110000) Motor Current Sense Too High
This fault occurs if the Motor Control Module detects that the motor current has reached an
unrealistically high level for greater than 2 seconds. This suggests that the motor current
sense circuit is faulty.
Primary source: Motor Control Module.
Action: Replace Motor Control Module.
Hi just read your posting.When the machine stops completely does the machine beep.If it does beep then a series of lights will light up.These lights will be in a row of 8 lights.Starting from the left to right which lights are on when the machine beeps,Is it the 2nd and 7th or the 1st and 6th etc?Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Hi just read your posting.Did you remove any wires to the control module which is located under the top panel when you replaced the bearings.Now did you put the cold inlet hose to the water valve marked with the letter C and the hot to H ?These letters are next to the valves.Have you got the Efficiency option button?Can you select a manual water level instead of just an auto fill?Have you tried to put the machine throe a spin cycle?Do you hear any water coming into the machine at all?Please with additional information to these questions and I am sure we can rectify this problem for you.
your machine is a fisher and paykel, just re-badged. now the fault you have is your " OUT OF BALANCE" switch is faulty, probably due to corrosion . the switch is located under the control module which is under your display panel. if you choose i can guide you thru the repair. please reply 4 further help
Fisher & Paykel GW608U Top loader washing mashine. On power up it will pass the self test, but then it goes to error (single beep every second and lights: green 3rd, 4th green and 7th orange from left are on). Could you advise on the problem please or supply error message codes table. Greatly appreciate your help and looking forward hearing from you
It sounds like you need to re programme the machine. With the machine plugged into the wall and turned on and the headset turned off this is what you do. Push and hold down the start button, while doing that you need to then push and hold down the power button. Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps. Then release the buttons. Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle. This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
