Question about Maytag Neptune MAH6500A Front Load Washer
Code Lr I'm getting a code Lr the machine also started jerking all over the place and attacking the walls, since its a front loader this should not be happening.
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" - the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source...
"Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 I'd call it a 3.5.
If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job.
It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear.
Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer.
The instructions don't ask you to, but I would remove the brace on the left to make life easier.
This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board.
My wrench was too big to get to the bolt to remove the harness from the motor.
All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor.
As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft.
The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together.
There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish.
Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question $$$$4
Posted on Oct 01, 2010
6ya staff
SOURCE:
Maytag Neptune front loader, model # MAH5500BWW had a digital error code reading Lr. Will not agitate or spin out.
the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit boardat the top of the unit has lost connection to the motor and its controlboard at the bottom (connector loose) or 2) the motor and or controlboard at the bottom have trashed and need to be replaced (P/N12002039).
Hope that helps,
Thanks,
Lee
Jul 11, 2008 | Maytag Washing Machines
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front lader washer maytag neptune
check the drain pump for a foreign object that maybe stopping the impellar wheel from turning.to remove the water use a shop vac attached to the drain hose to get all the water out
Sep 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer maytag FAN6800AWW get Lr alarm and dont start, what is thi
HI, this code is signaling an issue that concerns the actual electric motor. a service call is recommended if possible. either the MCU is bad or, the motor has completely failed.
Jun 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lr code appears. machine stops.
replace or, replace the lid lock switch,solenoid or, bent lock lever
Jun 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lr code on display
it is a problem with the motor .this is confirmed.
Issue
Washer stops in mid-cycle and/or flashes a code.
Warranty Standard product manufacturing warranty applies.
Action The motor drive system experienced a momentary loss of neutral feed from the power cord to the
Motor Control Board. The neutral line for the Motor Control Board passes across the water valve
solenoids. Neutral to the motor drive system can be momentarily lost If there is poor crimping of any
of the wire terminals in this circuit. This situation could result in a misdiagnosis and unnecessary
replacement of the Motor or Motor Controller Board.
Current Neptune front load washers will indicate a false locked rotor signal to the Machine Control
Board. Washers with a LED display will flash code “LR” in the display. LCD washers will display
“Locked Rotor.” The earlier built front loaders will not display a code, but simply shut down in midcycle
or will not start.
Pull each terminal of the white wire harness connected to each water valve solenoid and verify the
wire is properly stripped and crimped to the metal terminal connector of the wire harness. Make sure
the wires fit snug on the terminals of the water valve solenoids.
A product improvement has been made to the following models. The neutral wire is routed across
the pump only, and now by passes the water valve solenoids.
MAH55FLBWQ/W ..................... Series 12
MAH5500AWQ/W ..................... Series A7
MAH6500AWQ/W ..................... Series 33
MAH7500AWQ/W ..................... Series A6
May 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Display error code of Lr on control panel
L means "Lid or Door Lock" problem
r probably means 'release' I couldn't find it anywhere... so I'd guess that Lr means the machine did not detect that the Lid Lock released and cycle end (which means either the sensor is bad or the Lid Lock dosen't lock the Lid).
Either way, something with the Lid Lock system ais not right. Be glad it releases ;-)
Mar 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Code lr appears on washer
use normal cycle instead of clean just follow say instructions ..lr is code for remove clothes from tub for clean cycle problem even with no clothes they still show code ..it's a program problem that whirpool is aware of last i heard they were working on solution but instructing cust to just use normal cycle instead
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MAH6500A Front Load Washer Logo
48 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
